Transmission crossmember - Mustang Evolution
Old 03-25-2013, 02:26 PM   #1
fordtough1991's Avatar
I'm puting a 5.0 in a 91 Lx it had a four cylinder in it will the transmission crossmember work for my 5.0
fordtough1991 is offline   Reply With Quote
Old 03-25-2013, 06:38 PM   #2
Billymich's Avatar
I can't say for sure, but I would say if not, it would be easy to modify.
Old 03-25-2013, 08:14 PM   #3
Krazy Horse's Avatar
If its auto and your staying auto it will work, if manual swap from auto it will have to be changed
---------- Post added at 09:14 PM ---------- Previous post was at 09:13 PM ----------
I've done that very same swap, but you need to change the rear end too the 7.5 won't survive the torque of the v8
Krazy Horse is offline   Reply With Quote
Old 03-25-2013, 09:21 PM   #4
Thanks and does the crossmember also need to be move forward under the car there looks to be brackets to move the crossmember forward?
Old 03-25-2013, 09:28 PM   #5
Just remove it, set your drive train in place, then you will figure out which set of brackets will work. I had a 91 gt donor car, then swapped it to a 88 convertible. I just finished swapping it from manual back to auto so I could use the manual in my hatchback
---------- Post added at 10:28 PM ---------- Previous post was at 10:27 PM ----------
Oh yeah, use a small floor jack on wheels under tailshaft of trans for guidance and height adjustment
Old 03-25-2013, 09:29 PM   #6
Ok thanks! You helped me alot!
02:42 PM
