F303 cam help - Mustang Evolution
Old 03-26-2013, 04:54 PM   #1
Ronn501's Avatar
Region: Arkansas
F303 cam help
Does this cam burn alot of gas for a daily driver
Ronn501 is offline   Reply With Quote
Old 03-26-2013, 05:41 PM   #2
Any time you add performance you will most likely lose some mpgs. I would guess around 1-2 loose.
Old 03-26-2013, 08:29 PM   #3
Billymich's Avatar
b303 is better if you're not going forced induction I believe. (its possible I have it backwards)
Old 03-26-2013, 08:34 PM   #4
F303 is the bigger cam. it runs fine on na build but is ground for FI. B303 is pretty much an na cam.
Old 03-26-2013, 08:41 PM   #5
Billymich's Avatar
So if he was going to stay NA would a b303 with 1.7 rr be better?
Old 03-26-2013, 08:57 PM   #6
Probably. A b303 with 1.7 will close in lift to a f303 with 1.6. But its hard to say exactly which can would make most power as every setup varies. I would pick tfs stage 1 personally.
Old 03-26-2013, 11:41 PM   #7
Ronn501's Avatar
Region: Arkansas
I went and bought the f303 from ford racing thanks for your imput.. Now would y'all suggest i should get new valve springs???
Old 03-27-2013, 12:03 AM   #8
Yes. Check out a set of comp cams springs. I dont know the specs on the f cam off hand but i would definitely check your piston to valve clearance. Do you have a stock short block?
keaton5.0 is offline   Reply With Quote
Old 03-27-2013, 12:30 AM   #9
Billymich's Avatar
Congrats! Enjoy your new power!
Old 03-27-2013, 05:06 AM   #10
Nice! And yes you will need new valve springs.
Old 03-27-2013, 12:03 PM   #11
Ronn501's Avatar
Region: Arkansas
Thanks and yes it's at 1997 mercury mountaineer 302 gt40p
04:05 PM
