89 mustang horn - Mustang Evolution
Old 03-27-2013, 03:37 PM   #1
Vazqueza90's Avatar
89 mustang horn
So my mustang horn don't work, the steering wheel pad clicks when u press it, it has both horns and the fuses r good
Vazqueza90 is offline   Reply With Quote
Old 03-27-2013, 08:04 PM   #2
stevec666's Avatar
Check power to the horn when button is pushed if it is getting power then need new horn otherwise could be break in wiring or faulty horn switch.
stevec666 is offline   Reply With Quote
Old 03-27-2013, 08:10 PM   #3
Vazqueza90's Avatar
How do I do that.?
Old 03-27-2013, 08:22 PM   #4
stevec666's Avatar
Originally Posted by Vazqueza90 View Post
How do I do that.?
Get yourself a test light put it to the positive wire that goes to the horn and have someone else push the horn on the steering wheel. If it lights up you have power. Keep us posted.
Old 03-29-2013, 01:58 PM   #5
Vazqueza90's Avatar
So I have no power going to the horn
I also tried connection it to the battery directly and one worked and the other didn't
Old 03-29-2013, 05:44 PM   #6
stevec666's Avatar
Ok well you know now to check fuses and lastly if those check out you'll have to replace the horn switch.
Old 03-30-2013, 02:29 PM   #7
Vazqueza90's Avatar
So the fuses r good cause me cigarette lighter is working cannot be the horn relay
Canny test it
Old 03-30-2013, 02:35 PM   #8
stevec666's Avatar
Canny test it
Then in my opinion pick up a horn switch and you should be good to go.
Old 03-30-2013, 04:11 PM   #9
Vazqueza90's Avatar
Where can I find a horn switch.?
---------- Post added at 02:11 PM ---------- Previous post was at 02:08 PM ----------
Sorry about the misspelling b4
Can it be my horn relay my fuses r good cause my cigarette lighter works
The horn pad also clicks when I press it
Old 03-30-2013, 04:21 PM   #10
stevec666's Avatar
Any auto parts store should be able to order you one, they're pretty easy to do.
Old 03-30-2013, 04:59 PM   #11
Vazqueza90's Avatar
Where's the horn switch.?
Old 03-30-2013, 05:08 PM   #12
stevec666's Avatar
Right behind the center cover on the steering wheel.
Old 03-30-2013, 06:26 PM   #13
Vazqueza90's Avatar
Where is it.?
Is it the little black box
Old 03-30-2013, 06:34 PM   #14
stevec666's Avatar
That one is different than my setup because I have the airbag but should be that hole round piece that the wires connect to.
Old 03-30-2013, 06:59 PM   #15
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Did the horn work prior to ownership? Have you checked to make sure it is still plugged in on the steering column? I've seen people disconnect them there because the padding wears down and causes the contacts to touch making the horn blare until you disconnect it. Also could just be te horn is old and worn out in which ase it is located in between the driversside fender and inner fender.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 03-30-2013, 07:08 PM   #16
Vazqueza90's Avatar
When my dad owned the car it worked and it went out on him like 3 yrs ago and never fixed now that I have it
I'm fixing what needs fixing
I tried connecting a wire from the positive post if the battery to the positive hook up to the horn and only one horn honked(closest to the floor) and the other didn't
---------- Post added at 06:08 PM ---------- Previous post was at 06:05 PM ----------
How can u check if its still connected
Old 03-30-2013, 07:10 PM   #17
stevec666's Avatar
From that photo you put up it is definitely still connected.
08:43 PM
