Driveshaft Trouble - Mustang Evolution
Old 03-27-2013, 09:59 PM   #1
Billymich's Avatar
Driveshaft Trouble
So I recently rebuilt my clutch etc, I got my driveshaft on, but im having trouble getting it torqued down, I have 2 jack stands, 2 jacks. One jack is 20in of lift four ton. The other is 15in of lift or so and 2 ton. I need to get more room and jacking it up on the rear alone (using frame rails) doesn't help. Where else can I not only use as a jack point but a stand point. Do I need to use thread locker? Also I was doing some work under the car and I noticed a small (dryish) trail from right where the main rear seal is... the thing is I just replaced it with a new one and I don't want to tear down again is it possible its leaking??!
Old 03-27-2013, 11:57 PM   #2
I jack mine right under the center of the differential housing.
Old 03-28-2013, 01:28 AM   #3
Billymich's Avatar
Thanks then put the stands under the axle??
Old 03-28-2013, 01:36 AM   #4
Yes. And use threadlock. Not sure about your mainseal, but if there's alot of miles on the engine the seal wears a groove in the crank.
Old 03-28-2013, 02:45 PM   #5
The drive shaft bolts are easy to get to as long as you turn the shaft to get to each bolt.
Old 03-28-2013, 03:18 PM   #6
Billymich's Avatar
Still didnt have enough room to move my torque wrench =( but i got it to about 50ft/lbs and used threadlocker
Old 03-28-2013, 10:02 PM   #7
Iv never used a torque wrench on a driveshaft and iv pulled them off of numerous vehicles. I just tighten them up as much as i can with a wrench and use some locktite. And check to make sure they didnt start backing out after a little driving
keaton5.0 is offline   Reply With Quote
Old 03-28-2013, 10:04 PM   #8
Yeah true dat yo. Lol
I use a swivel on my impact.
Old 03-29-2013, 02:02 AM   #9
Lmao. Swivel and an impact!!?!? I didn't even think of that. Really, the job could probably be done with the car on the ground, using a combination of swivels and long extensions. Lol.
Old 03-29-2013, 08:13 AM   #10
Seriously. I used a short extension with an impact swivel. Works great!
Old 03-29-2013, 08:46 AM   #11
I lay on my back and slide under with a 12 point 12mm wrench lol but my car isnt lowered any and im just a little fella so its not much trouble for me
Old 03-29-2013, 12:39 PM   #12
Arrow
Hmmm. Im not familiar with an impact swivel. WTF!?! Am I really that out of touch?
Old 03-29-2013, 08:50 PM   #13
Billymich's Avatar
Well generally I try to torque to spec. That's just me.
07:36 PM
