Issues - Mustang Evolution
Old 03-28-2013, 09:56 PM   #1
Issues
My 89 5.0 has loss of power. Wont even move when gas is pressed. Any sugestions
Stangdan is offline   Reply With Quote
Old 03-28-2013, 10:05 PM   #2
Sudden? Gradual? Any other symptoms of info? Good be anything at this point. The more info the better.
Old 03-28-2013, 10:17 PM   #3
Gradual. Been parked for more than a year now. It tirns on with some trouble but once warmed up it will stay on. Sounds good just that when i press on gas it studders and sometimes dies. I wanna go with a mechanic to check specifics from what i can get from help from here. Preciate ur help. When in drive it wont go. Tune up done with no improvements. What else could it b.
Old 03-28-2013, 10:30 PM   #4
The tfi module on the distributor could cause that issue. I would test that first and go from there. There is a link in the stickies that shows you how to test it. Also when you did the tune up did you also replace the cap and rotor?
keaton5.0 is offline   Reply With Quote
Old 03-28-2013, 10:47 PM   #5
Cap and roter was not replaced. I will though
Old 09-07-2013, 04:09 PM   #6
Tfi checked and it still good. Any suggestions where to check next. Preciate da help
Old 09-07-2013, 06:56 PM   #7
Ohdang1990's Avatar
I had a very similar problem when I rebuilt the top end on my 88. Started up and idled great. I got it out in the street and pushed the gas and it sputtered and barely went anywhere. Turns out my timing was was 180'd out even though I had marked my distributor. Check your timing.
Ohdang1990 is offline   Reply With Quote
Old 09-11-2013, 08:01 AM   #8
bnoist114's Avatar
I would definately check the timing. It sounds like its stumbling because of too much fuel. But that could be caused by the timing being out of whack an its not being burned properly. Good luck man
bnoist114 is offline   Reply With Quote
12:12 PM
