Need some help - Mustang Evolution
Old 04-08-2013, 11:14 AM   #1
Cblackstang's Avatar
Need some help
My power locks are going crazy it keeps locking until it runs the battery completely dead..any advice? I've already changed the module in the trunk
Cblackstang is offline   Reply With Quote
Old 04-13-2013, 07:15 PM   #2
Anyone?
Old 04-13-2013, 07:24 PM   #3
89notchbeast's Avatar
Wow....did it just start doing it one day?
89notchbeast is offline   Reply With Quote
Old 04-13-2013, 07:35 PM   #4
Yea out of the blue just started cycling until the battery died...I changed the module and didn't help the only thing I can think of is just unplugging it
Old 04-13-2013, 08:23 PM   #5
Good call...I would replace the fuse and try and track down the wires to see if there ok....maybe the switch itself?
---------- Post added at 09:23 PM ---------- Previous post was at 09:19 PM ----------
Make sure it's the right amp fuse also....if someone put a higher amp fuse in it would work Temporarily but would take its toll on the wires from what I'm told
Old 04-13-2013, 08:56 PM   #6
Alrite I was gonna check the relay possibly sticking
Old 04-17-2013, 06:29 AM   #7
94gtconvert's Avatar
You should buy a keyless entry fob on eBay for 10 bucks and program a new remote to it. Unless you already have one then try re programming it. It's on the module you changed. Just short out the 2 prongs in the grey harness on the module with acc electric on (the Key half way on). Leave your window down short it out. Then press lock on the key remote and it will erase all old key fob codes or refresh if u use the same one.
94gtconvert is offline   Reply With Quote
01:43 PM
