Need help with lug conversion - Mustang Evolution
Old 04-08-2013, 07:56 PM   #1
Hi everybody just got a 90 mustang gt conv
and want to convert to a 5 lug with saleen wheels
18x10 rear with a 295 tire whats the best way to go
about it thx in advance
prcmauricio is offline   Reply With Quote
Old 04-08-2013, 08:20 PM   #2
aegischief's Avatar
First congrats on the car.
I'm not certain that big of a wheel tire combo will work. A 275 tire is a squeeze. You are probably looking at some sheet metal bending to get a tire that size to fit.
As far as five lug conversion, I say get a ford HD differential since it will upgrade you to 31 spline, a set of moser 31 spline axles. Since you are in the rearend already go ahead and install a set of 3.73 gears. The cheapest way is to get a couple of ford ranger axles, left sides I believe, an stick them in. You can get those from a junk yard or swap meet. For the front get a set of spindles from a 94-95 GT. Can get them at a junk yard or swap meet as well.
Good luck.
aegischief is offline   Reply With Quote
Old 04-08-2013, 08:35 PM   #3
295 won't fit without modifying the inner fender. I have a set on my 90 but they rub like crazy.
Old 04-08-2013, 08:43 PM   #4
aegischief's Avatar
I thought so. My buddy had 275s on his 93 an they rubbed some.
Old 04-08-2013, 09:11 PM   #5
93slowstang's Avatar
For the front: complete spindles off of a 94-95 gt or v6, they are the same. If you're not changing the ball joints then you will need 5/8 washers at least .330" thick since the fox ball joint is taller than the sn95 ball joint.
Rear:
You need the passenger side Aerostar (any year) axles or driver side ranger axles ( can't remember the years). If you want to stay cheap just get the Aerostar 9" drum along with the axles.
And with the correct offset you can fit the 18x10" but you will need to remove your quad shocks and I would suggest upgrading your control arms.
Old 04-08-2013, 09:12 PM   #6
My 275's never rubbed.
Old 04-10-2013, 02:48 PM   #7
Thx for all the help guys
5lug conversion Lou89lx5.0 General Mustang Discussion 4 01-18-2014 05:33 PM
? On 5 Lug Swap SleepingStang 1979-1995 Mustang GT 8 01-05-2012 09:16 AM
4 lug wheels my65 Mustang Wheels & Tires 1 11-09-2011 07:41 AM
5 lug conversion ? my90gtamfw 1979-1995 Mustang GT 4 10-17-2011 07:14 PM
Locking Lug Nut Ket, Where is it? dacriss General Mustang Discussion 3 07-01-2011 08:17 PM
03:29 PM
