What intake manifold should i get - Mustang Evolution
Old 04-09-2013, 11:25 AM   #1
Dustin541's Avatar
Region: Oregon
So it's time for an intake manifold for my gt so far it's got a x303 cam track heat 170 heads 24# injectors CAI remanufactured 302 bored .030 over(306) right now it has a gt40 explorer intake on it what would be a good intake manifold for my setup???
Car has 3.55 gears and 26" 11.50 et streets on it and its a track car now
Dustin541 is offline   Reply With Quote
Old 04-09-2013, 11:45 AM   #2
WhiteCobra94's Avatar
I'd go with the Holley SystemMax II intake manifold , can't go wrong with it!!
---------- Post added at 11:45 AM ---------- Previous post was at 11:43 AM ----------
You may want to upgrade to 30lb injectors to avoid the problem I ran into !!
---------- Post added at 11:45 AM ---------- Previous post was at 11:45 AM ----------
Old 04-10-2013, 06:08 AM   #3
Dion11197's Avatar
Yup, the Holly is a strong piece! The RPM perormer 2 is a good one also.
Dion11197 is offline   Reply With Quote
Old 04-10-2013, 09:26 AM   #4
+1 I'm in the process of looking for just the Upper RPM II, I'm running the Performer which use the same base as the RPM II
Old 04-10-2013, 10:11 AM   #5
Ewokjax95's Avatar
Have you checked Summt? I thought for sure they would have it. Or you could call or email Edelbrock themselves. I'm sure you've already done this tho.
Ewokjax95 is offline   Reply With Quote
Old 04-10-2013, 01:58 PM   #6
I'm gonna have to call Edelbrock , no one sells just the upper for the RPM II
Old 04-10-2013, 03:04 PM   #7
jduckz5.0's Avatar
I just bought my 90 gt..it has victor Jr heads,e303 cam,long tube headers,flowmasters,373 gears,cheap spectre fender air tube n filter...what mass air,throttle body an d intake should I get???? Want for street mostly...want low end torque to b strong...
jduckz5.0 is offline   Reply With Quote
Old 04-10-2013, 04:32 PM   #8
Adogg's Avatar
Not trying to be weird but what are you doing with the gt40 intake after?
Don't hate....... appreciate
Old 04-10-2013, 10:02 PM   #9
havhammer's Avatar
Why you need/want a gt40 explorer intake?
havhammer is online now   Reply With Quote
Old 04-11-2013, 08:08 AM   #10
Dion11197's Avatar
Most people who get them are looking for a cheap upgrade to the stock intake. You can get an explorer intake for $100-250 vs the almost identical flowing cobra.
Old 04-11-2013, 10:34 AM   #11
Finchms's Avatar
Since u have the tf heads then y not go with tf intake?!
Finchms is offline   Reply With Quote
Old 04-19-2013, 03:44 PM   #12
Dustin541's Avatar
Region: Oregon
Got a killer deal on a professional products intake polished for 1
Old 04-19-2013, 03:53 PM   #13
Dustin541's Avatar
Region: Oregon
Having running problems tho sometimes it starts perfectly fine and ten other times it just turns over and over then I spray starting fluid in it and it fires up and runs totally normal so what's the problem
Old 04-19-2013, 04:22 PM   #14
Is your problem with hot starting or cold starting? I ask because this changes the posibility of what the problem is.
A TFS intake is an optimum choice for your TFS heads. Should you ever decide to port your heads the TFS intake can be easily ported to match maximizing your power. The Holley Systemax is a great intake but is a better match for TFS HighPort heads. A match ported Edelbrock Performer 2 would be a good choice if your heads are already ported.
The StreetHeat or TrackHeat heads that have the same casting as the Twisted Wedge heads with the TrackHeats just having no smog provisions and higher lift capable springs are the heads your running? If this is the case and you ARE running TrackHeat Heads the size of your TB is the determining factor in which you should run, the TFS Street or Track intake. The TFS Street and Track Heat intakes have the same lower but the Track verson has a bigger upper and handles a larger TB and will maxmize your top end rpm track power. If your heads are actually Twisted Wedges the Street Heat Intake is the best you can run due to the heads smog provisions.
Advice: Look to foxlakeracing for your porting needs.
DieselStang is offline   Reply With Quote
Old 04-20-2013, 12:50 PM   #15
Dustin541's Avatar
Region: Oregon
It's random sometimes it starts fine hot or cold other times it just turns over and over I have track heat heads brand new non ported I got a killer deal on a typhoon intake so that's what I am running right now currently a stock throttle body but I want to get it running before I spenders money making it faster
10:02 AM
