Belt size - Mustang Evolution
Old 04-09-2013, 06:07 PM   #1
Stangfan21's Avatar
Belt size
I've got a 95 gt and I'm bypassing the smog pump and running everything else anyone know what size belt that takes cause local parts stores can't seem to get it right
Stangfan21 is offline   Reply With Quote
Old 04-09-2013, 06:20 PM   #2
WhiteCobra94's Avatar
Idk what size as in inches, you can take some string and run it through the pulleys and see but I highly recommend getting the smog pump delete kit for $80
Old 04-09-2013, 06:24 PM   #3
Stangfan21's Avatar
Cool thank you ill definitely get one so I I can just get a factory belt and not worry about the size
Old 04-09-2013, 06:51 PM   #4
DerekJohnScott's Avatar
What's the delete do?
DerekJohnScott is offline   Reply With Quote
Old 04-09-2013, 09:01 PM   #5
The delete is just a aluminum bracket and pulley that takes the place of the smog pump
Old 04-09-2013, 10:12 PM   #6
And why is that better than just getting a smaller belt? Sorry for the questions I'm just curious.
Old 04-11-2013, 03:24 PM   #7
Not 100% sure but that's what the speed shop told me before I dropped it off for dyno
Old 04-11-2013, 05:55 PM   #8
Dion11197's Avatar
It's not really any better, but it takes the guess work out of the belt size. With the delete you can still use the stock belt and never have an issue when it comes to replacement.
If you just take it off and try a shorter belt, what most guys do is reverse the spring in their tensioner and that allows different belts. Just from my experience its hard to find the exact size you need, hence the tensioner reversal. Most are either too tight or too loose.
Dion11197 is offline   Reply With Quote
Old 04-11-2013, 07:40 PM   #9
That makes sense. Thanks for the answer.
Old 04-12-2013, 04:49 AM   #10
Dion11197's Avatar
No problem! That's on my long lost of things to do on mine to. Right now I've it the pump still there and nothing attached to it. The bad part is the previous owner just replaced the pump prior to my purchase.
Old 04-13-2013, 07:51 AM   #11
Take it off and sell it "like new"
Old 04-13-2013, 11:20 AM   #12
Dion11197's Avatar
I like that idea!!
04:28 AM
