HELP - Mustang Evolution
Old 04-11-2013, 08:29 AM   #1
Vazqueza90's Avatar
I started my 89 mustang today(3 month starter) and it sounded as if the starter was just spinning on its on without turning the car
Tried 2 times b4 it started
1st time it jus sounded like it was spinning by itself
Can it be loose.?
Vazqueza90 is offline   Reply With Quote
Old 04-11-2013, 09:40 AM   #2
More than likely it is the solenoid that pushes out the little gear to engage the starter that is malfunctioning.
Adam302gt is offline   Reply With Quote
Old 04-11-2013, 12:20 PM   #3
Dion11197's Avatar
+1, I also had the same issue but ended up being the battery was too low on charge.
Dion11197 is offline   Reply With Quote
Old 04-11-2013, 01:11 PM   #4
Vazqueza90's Avatar
Shoul I jus get a new starter.?
Old 04-11-2013, 01:15 PM   #5
Kind of a pain, but if you pull the starter they can bench test it at any oreiley's, autozone, etc. They can also test the battery under load and see if that is weak and contributing to the issue.
Old 04-11-2013, 01:32 PM   #6
Vazqueza90's Avatar
I have a 3G alt with a overdrive pulley
It's charging great
14+ on with lights and heater
Car Off is 12+
Old 04-11-2013, 03:02 PM   #7
Dion11197's Avatar
Of your battery is good then it's definitely a starter issue.
Old 04-11-2013, 04:08 PM   #8
Vazqueza90's Avatar
I have lifetime warranty on it
Ill jus switch it out
Old 04-11-2013, 04:27 PM   #9
Boomdizzle's Avatar
Sounds like it's the starter. I had the same issue a few years back and that was what it was.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
11:28 AM
