to much fuel - Mustang Evolution
Old 04-11-2013, 11:26 AM   #1
FordRacer_51's Avatar
to much fuel
Ok I put together an 88 5.0 for my dad stock heads and a gt 40 intake with 19lbs injectors and 65mm tb and its getting to much fuel any ideas??
FordRacer_51 is offline   Reply With Quote
Old 04-11-2013, 11:29 AM   #2
Dion11197's Avatar
Check the fuel pressure.
Dion11197 is offline   Reply With Quote
Old 04-11-2013, 11:32 AM   #3
Do I have to change the regulator??
Old 04-11-2013, 12:05 PM   #4
Dion11197's Avatar
Honestly it wouldn't be a bad idea to get an adjustable fuel pressure regulator. Thy way you can dial in your pressure for the current combo or turn it up if you need more for future mods.
Old 04-11-2013, 12:09 PM   #5
garbill2003's Avatar
X2 this can be fixed with a regulator I would also put a fuel pressure gauge in it to.
garbill2003 is offline   Reply With Quote
Old 04-12-2013, 10:36 AM   #6
DustyStang306's Avatar
You shouldn't be getting to much with the 19# injectors are stock an fuel pressure at the rails should be 38psi to like 40psi with vacuum removed from the fuel regulator but you could have a stuck open injector making it run rich in one cylinder but for stock heads an gt40 intake you shouldnt need anymore then 19# injector with that set up
DustyStang306 is offline   Reply With Quote
Old 04-12-2013, 06:48 PM   #7
Do I need the vac hooked up and if so does it matter where I plug it into??
---------- Post added at 08:48 PM ---------- Previous post was at 08:47 PM ----------
Not sound like a dumb ***.
Old 04-12-2013, 07:22 PM   #8
91notchback's Avatar
Unhook vaccum an plug it with something. So it dosent pull a "load".
91notchback is offline   Reply With Quote
Old 04-14-2013, 07:38 PM   #9
Does it matter that its not maf its speed density
Old 04-14-2013, 08:11 PM   #10
No sir.
07:36 PM
