starting problem - Page 2 - Mustang Evolution
Old 04-17-2013, 10:32 AM   #36
Dion11197's Avatar
Should be a plug all by itself close to the distributor, although since your ignition module is close to your air box it probably is to. Should be orange/yellow I think.
Dion11197 is offline   Reply With Quote
Old 04-17-2013, 10:38 AM   #37
moyhuerta91's Avatar
ill take a picture of it right now when i get a chance
moyhuerta91 is offline   Reply With Quote
Old 04-17-2013, 11:00 AM   #38
Dion11197's Avatar
Ok
Old 04-17-2013, 11:08 AM   #39
is this the one u r talking about
Old 04-17-2013, 12:59 PM   #40
Dion11197's Avatar
That looks like the one!
Old 04-17-2013, 01:03 PM   #41
oh kk..i have a question on that a long time afo.some guy dat was doing my smog test was trying to put dat chip back and he droped it nd lost it nd he replaced it with another one will dat affect anything?
Old 04-17-2013, 01:26 PM   #42
93slowstang's Avatar
No, all it is is a jumper that allows the ecu to control advance and ****** functions of the ignition system. Pulling it allows you to set the base timing without the computer trying to compensate.
Old 04-17-2013, 01:29 PM   #43
oh ok i understand how much do people charge to do fix a timing
Old 04-17-2013, 01:44 PM   #44
91notchback's Avatar
Just buy a timing light and fix it bro. They'll prolly charge you more than the light costs...
91notchback is offline   Reply With Quote
Old 04-17-2013, 01:48 PM   #45
how much is the timing light???
Old 04-17-2013, 02:02 PM   #46
I bought a kick *** one for $50.
Old 04-17-2013, 02:08 PM   #47
what were???
Old 04-17-2013, 02:10 PM   #48
I just got it from a local parts store. Then you'll have it when you need it!
Old 04-17-2013, 02:21 PM   #49
I want to buy one but not an expensive one.
Old 04-17-2013, 02:34 PM   #50
Like I say: you'll spend more gettin someone to do it for you than buyin your own light.
Old 04-17-2013, 02:39 PM   #51
well thats true
Old 04-17-2013, 04:31 PM   #52
i found a timing light at autozone one is 40 nd the other one 100 wats the diffrence
Old 04-17-2013, 05:00 PM   #53
For your problem, and stuff in the future, $40 is good. I'm a DIY guy, and my low priced works awesome!!
Old 04-17-2013, 05:36 PM   #54
ill just buy the 40 buck one i hope it works
Old 04-17-2013, 11:31 PM   #55
i just have one problem idk how exacly now how to use it nd how many dagrees its suposed to be
Old 04-18-2013, 06:21 AM   #56
Dion11197's Avatar
It's been a LONG time since I've done this.... I'm sure someone can correct me if I'm wrong..... Step one, start car.... Step two, hook up timing light (can be done at any point really). Step three, pull spout connector and loosen distributor bolt enough so you can turn the distributor by hand (not much, only takes like a quarter to half a turn). Step four, with timing light, press button (pull trigger) and it will flash in pulses.... Shine down at balancer, you will see markings with numbers and lines, these are your degrees of timing. There is a metal indicator that looks like a pointer, that is your reference point for your timing. Whatever number is at the point, that's your base timing. Rotate distributor either way slightly and slowly and watch with your timing light. I believe your base timing should be 10 degrees, I think! You can advance to 12-14 degrees if your running premium gas, but if you set your timing and you here pinging under load that sounds like a rattle can, either back down timing (****** it) or put better gas in it. Once you've got your timing set, tighten distributor bolt and recheck, if it hasn't moved, replace your spout connector and go for a drive, listen for pinging, if none, good to go!
Old 04-18-2013, 08:10 AM   #57
oh kk it sounds pretty easy. i always run wit chevron suprem gas 91.
Old 04-18-2013, 08:22 AM   #58
Dion11197's Avatar
It is, and only takes a few minutes.
Old 04-18-2013, 08:31 AM   #59
Oh ok...i have a question my car rattels like a can when i press the throttle nd i hit around 45 nd up it or sometimes from 20 nd up it sounds nasty wat could that be
Old 04-18-2013, 01:16 PM   #60
Dion11197's Avatar
I mentioned it before, too much timing or too low octane gas.
Old 04-18-2013, 03:07 PM   #61
oh kk i get u man...i bought the timing light its the one dat is 100 bucks ill take a pic of right now. see if dis one is wortj 100 bucks
Old 04-18-2013, 03:09 PM   #62
Old 04-19-2013, 04:49 AM   #63
Dion11197's Avatar
That looks like a good one, but I think the cheaper one will be all you need.
---------- Post added at 03:49 AM ---------- Previous post was at 03:48 AM ----------
Since you haven't gotten a light yet, was the car making the noise before you set the timing?
Old 04-19-2013, 08:07 AM   #64
i.bought the light yesterday i have it already.yes but i cant remember how did it start but dat sound loks like it comes from.the transmission
Old 04-19-2013, 05:59 PM   #65
Dion11197's Avatar
Of its whole you are accelerating it's more than likely the motor. Just be careful and don't drive much if it's doing it. It can cause damage to the motor. If you're already running premium gas, you definitely need to check your timing.
Old 04-19-2013, 06:17 PM   #66
What part of the motor could it be do u have any clue. i always run 91 on gas chevron. i tryed to do it but the number on the pully or watever is called i cant see them cuz is so dirty so i cant see wat degree is located at right now. i need to clean it first befor i do the timing
Old 04-19-2013, 06:34 PM   #67
Crawl under it. Wipe it down and find the degree you're looking for. Get some kinda fine tip white (or bright color) paint pen and make a line.
Old 04-19-2013, 06:38 PM   #68
yea ill cleand dat up wen i get a time cuz i really wamt to check dat out
Old 04-19-2013, 07:11 PM   #69
Dion11197's Avatar
Yeah, the coloring is highly recommended and a great idea!
When it makes that sound... If its coming from the engine, it's a thing called detonation, it happens in the cylinder. It's basically a pre ignition when it's not supposed to happen. It can lead to piston and cylinder wall damage.
Old 04-19-2013, 07:20 PM   #70
is their a way to check dat or something
09:06 AM
