starting problem - Page 3 - Mustang Evolution
Old 04-19-2013, 08:47 PM   #71
Dion11197's Avatar
Just by listening really, you can see evidence of it on the top of the pistons And if I remember correctly it can cause your spark plugs to fail.
Dion11197 is offline   Reply With Quote
Old 04-20-2013, 10:51 AM   #72
moyhuerta91's Avatar
So if dats wat it is i would have to replace the pistons nd everything dat is damaged or wat.
moyhuerta91 is offline   Reply With Quote
Old 04-20-2013, 11:38 AM   #73
91notchback's Avatar
Time you're car out correctly and see what it does. Pinging is the result of your timing being too advanced and the gas mixture igniting prematurely.
91notchback is offline   Reply With Quote
Old 04-20-2013, 11:55 AM   #74
Dion11197's Avatar
No, you should be fine. As 91 notch stated, just make sure you adjust your timing properly and you'll be good to go. Wouldn't be a bad idea to check your plugs to to make sure they are gapped correctly.
Old 04-20-2013, 08:38 PM   #75
i tryed doing my timing nd it made the pinging noise even more anoying wen it hits 2500 rpm it makes the pinging sound every gear. well supposably my mechanic gaped the corectly
Old 04-20-2013, 08:56 PM   #76
Dion11197's Avatar
What did you set the timing at?
Old 04-20-2013, 08:58 PM   #77
i cant really tell cuz the numbers i cant really see them well so it hard to tell
Old 04-20-2013, 09:05 PM   #78
Dion11197's Avatar
Ah, then yeah, you need to clean it so you can see, otherwise you could be doing more harm then good if you are trying to set it without a reference.
Old 04-20-2013, 10:53 PM   #79
like i tryed cleaning it but the numbers are hard to see nd hard to tell wat number is it...i was driving my car right now nd it wasnt doing it idk dis is weird
Old 04-21-2013, 02:09 AM   #80
Lay under the car and have someone bump the starter over until the numbers are right in front of your face. Or you can do it all yourself by going back and forth, that's what I did last time.
Old 04-21-2013, 06:58 AM   #81
Dion11197's Avatar
If you are going to have someone help you or do it yourself, I would disconnect the coil wire so you don't have to worry about it starting while your under there. I would wear some good goggles or glasses and use some shop towels and carb cleaner to clean the balancer up. Once you clean it up, as was stated earlier, get a decent paint pen and mark the number ten. When your timing light hits it, it will almost glow. But until you clean it, there's no point in messing with your timing.
Old 04-21-2013, 09:56 AM   #82
oh alright thanx bro i didnt know that
---------- Post added at 10:56 AM ---------- Previous post was at 10:53 AM ----------
oh Lright ill do dat wen i get a chance. hey man u have been realy helpful i thank u a lot man
Old 04-21-2013, 10:05 AM   #83
Dion11197's Avatar
No problem man! Let us know how it goes.
Old 04-21-2013, 10:17 AM   #84
yea man i will i will try it tomarrow cuz im going to be a lil busy today.
Old 04-21-2013, 08:35 PM   #85
89notchbeast's Avatar
Also I would check tps voltage
89notchbeast is offline   Reply With Quote
Old 04-21-2013, 08:58 PM   #86
were would i check dat at
Old 04-21-2013, 09:02 PM   #87
First things first now: you said you set your timing without knowing a baseline number. Get that straight first. TPS voltage should be .98-.99. I think it's in a different spot on your sn95 than on my fox. Its the red and green wires though with a voltmeter.
Old 04-21-2013, 09:59 PM   #88
I had similar problem it was the tps....there is a lot of threads on the web that will take you step by step how to check the voltage and can tell you the symptoms of a bad tps
Old 04-21-2013, 10:28 PM   #89
Agreed sir. But further up in the thread, he said he set his timing without knowing what number was on the harmonic balancer. TPS ain't gomna do nothin right now to fix the situation...
Old 04-21-2013, 11:37 PM   #90
kk..by tomarrow i will give u guys info about my timing i need to fix dat nd ill see wat happends nd i will start from their
Old 04-21-2013, 11:39 PM   #91
Yes sir. One thing at a time. If not, it all gets ****ed up!!
Old 04-21-2013, 11:48 PM   #92
haha dats true..i will give u guys info tomarrow?
Old 04-21-2013, 11:54 PM   #93
Yes sir. I'll be here.
Old 04-26-2013, 05:44 PM   #94
hey was up guys sorry for not giving u guys info but i finaly did my timing right
Old 04-27-2013, 07:19 AM   #95
Dion11197's Avatar
And how's she run now?
Old 04-27-2013, 08:31 AM   #96
i didnt get a chance to.take it out but i will today and let u konw...i have a question i fixed the timing were its supposed to be at 10 degrees but wen i connect the spout connnecter back on it the timing goes off does it supposed to do that??
Old 04-27-2013, 09:22 AM   #97
Dion11197's Avatar
Yeah, that means its working properly.
Old 04-27-2013, 09:33 AM   #98
oh alright thanx man u have helped me a lot..ill take it out today nd ill let u know if it runs like a champ or not haha
Old 04-27-2013, 11:38 AM   #99
Dion11197's Avatar
For sure!
Old 04-27-2013, 12:44 PM   #100
i drove it right now but my car was running like if it struggles to run cuz wen.i hit the throttle it dosnt pull like it supposed to
Old 04-27-2013, 02:27 PM   #101
Dion11197's Avatar
There's gotta be more going on. If your timing is right you may have a problem elsewhere. How was the pinging? Gone or still there? Did someone advance the timing before? If your timing was advanced before and you put it back to base of 10 then it may feel a bit sluggish. And are you having the original problem of starting issues?
Old 04-27-2013, 02:39 PM   #102
dat i now no one has done the timing i have had my car for like 3 or so years nd dis is the first time ive done it. i havent heard the pinging anymore. wat do u mean by starting problems??
Old 04-27-2013, 02:49 PM   #103
Dion11197's Avatar
That was your original post....... That you were having problems with the car not starting sometimes??????
Old 04-27-2013, 03:01 PM   #104
haha im sorry well the weird thibg is that when i go to skool it dosnt want to start idk if its because it dosnt get warm enought cuz the school is 5 min away from my house but if i go some were else it starts right away i dont know its weired nd confusing
Old 04-27-2013, 08:59 PM   #105
Dion11197's Avatar
How many miles are in the car?
02:57 PM
