starting problem - Page 4 - Mustang Evolution
Old 04-28-2013, 12:02 AM   #106
moyhuerta91's Avatar
well to tell u the truth idk cuz my car is selvaged nd idk the history of the car nd the thing were it shows the miles it dosnt work but it says it has 123,xxx miles
moyhuerta91 is offline   Reply With Quote
Old 04-28-2013, 07:34 AM   #107
Dion11197's Avatar
Well if you've had it for 3 yrs and the odometer has never worked, you're looking at probably 160,000 plus miles and that's if it broke right before you got it (probably not the case). You could be closer to 200,000. The motor is probably low on compression due to being old and tired. I would say that's your starting problem.
Dion11197 is offline   Reply With Quote
Old 04-28-2013, 09:20 AM   #108
it tell u the truth idk how much miles it has cus the meter was already been broken since i bought it. u could not fix the compresion anymore or wat coiuld i do
Old 04-28-2013, 11:11 AM   #109
Dion11197's Avatar
The only fix for low compression is a new motor, so if it just takes two or three cranks to start, I'd just live with it. If its low on compression that would also explain the less than impressive performance as well. These motors will last a long time as long as you perform regular maintenance and do your scheduled tune ups.
Old 04-28-2013, 11:25 AM   #110
deam i dont have money for a motor swap..but the weird thing is wen i diconnect the MAF sensor it runs like it supposed to run it responds right away nd it pulls good nd burns out real good to wat could dat be
Old 04-28-2013, 12:23 PM   #111
Dion11197's Avatar
Does it affect the starting issue?
Usually I would say that's a MAF sensor issue. The problem with running without your MAF hooked up is your computer goes into a default mode, a safe mode. Your computer cannot correct the air/fuel ratio based on the amount of airflow the MAF sensor is picking up, so you could be hurting you engine if your going out doing burnouts and stuff with it unhooked. Try cleaning your MAF sensor.
Old 04-28-2013, 12:35 PM   #112
no its the same thing but i havent got a starter issue for a while. i had just done dat once i dont diconnect it anymore i have cleand my MAF twice alread nd it dost change its the same thing wit low power u think if i buy a new one like a it will be better???
Old 04-28-2013, 01:58 PM   #113
Dion11197's Avatar
I'm sure there's something here on the site on how to test your MAF sensor, maybe in the stickies section. I always recommend checking before replacing it. I don't like spending money I don't have to.
Old 04-28-2013, 04:44 PM   #114
93slowstang's Avatar
Yes there should be something in the stickies for it.
Old 04-28-2013, 04:52 PM   #115
Old 04-28-2013, 09:02 PM   #116
SN95.'s Avatar
The first thing I thought of when you said it sometimes doesn't start or cuts out when driving was check the battery cables. See if they are loose or corroded. When I bought my 95 gt the connectors to the terminals were all rigged up and loose. If I hit a bump right it would cut out for a sec and drive like **** or wouldn't start til I wiggled the wires. Just a thought.
SN95. is offline   Reply With Quote
Old 04-28-2013, 11:39 PM   #117
were would i find the stickies. the cabel are caroded nd dat did do the same i will wiggle the cabel nd it wil turn on but i changed my terminals
---------- Post added at 12:39 AM ---------- Previous post was at 12:38 AM ----------
were would i find the stickies. the cabel are caroded nd dat did do the same i will wiggle the cabel nd it wil turn on but i changed my terminals.
Old 04-29-2013, 05:36 AM   #118
Dion11197's Avatar
Depends on if your on a phone or computer. I know the phone app you just go to the main forums page for the 1979-1995 mustangs and at the top there will be a link that's says stickies.
Old 04-29-2013, 08:46 AM   #119
oh kk ill check dat out nd il let u know wat happends
Old 05-04-2013, 09:18 AM   #120
SN95.'s Avatar
Any new news yet?
Old 05-04-2013, 09:26 AM   #121
well i have had some starting problems yesterday but it was my terminal that cracked. And my MAF sensor i cleand it i put on my cold air intake nd it runed a little bit but it still runs sloppy.
Old 05-05-2013, 09:40 AM   #122
Dion11197's Avatar
So it seams your starting problems may be fixed, describe the sloppy running....
Old 05-05-2013, 09:48 AM   #123
actully my starting problem hasnt got fixed cuz it shuts down on me still i dont know what to do anymore yesterday wen my car shut down on me i was on the side of the road i open my hood wen i did dat i heard like a clicking noise like if something turnd on nd i tryed turning it on nd my car did start. About my car running sloppy like it still disnt respond right i have to accelorate slow so it could pick up spead but if i hit the throttle it just dosnt respond to it.
Old 05-05-2013, 09:56 AM   #124
Dion11197's Avatar
I'm having trouble following.... So it starts and then shuts off? Or starts fine and runs but shuts off later? Your original problem/post was about not starting sometimes like at school... It's still doing that too?
Old 05-05-2013, 10:01 AM   #125
my car will start fine and everything but i will drive it and just shuts down out of the no were. but like yesterday wen i was stuck on the side of the road i was looking under the hood to see if i could see anything but like then i hear something click nd turn on like if its the starter or something i dont knoww
Old 05-05-2013, 10:38 AM   #126
Dion11197's Avatar
I would check all your plug wires to see if you have a wire arcing somewhere..... If you heard clicking it could be something ignition related.
Old 05-05-2013, 10:50 AM   #127
wat does arcing mean???to do dat i follow the posative wire right?? like wat do have to look for
Old 05-05-2013, 11:21 AM   #128
Dion11197's Avatar
What I'm talking about is your spark plug wires. Follow each one from the distributor to the plug and look or any signs of burning or exposed wire. Arcing is when you have electricity moving from one point to another.... Example... When you have your negative terminal hooked up then touch the positive to the positive terminal.... The sparks are when it arcs.
Old 05-05-2013, 11:31 AM   #129
so like wen u disconect the battery nd u connect it bakk it makes a clicking noice right
Old 05-05-2013, 01:57 PM   #130
Dion11197's Avatar
Yeah, and you'll usually see sparks.
Old 05-05-2013, 02:09 PM   #131
so dats wats happening to my car then im going to have to check the spark plugs
Old 05-05-2013, 08:25 PM   #132
Dion11197's Avatar
Could be, just check all your wires from the distributor cap all the way to the plugs. Would be a bad idea to check the boots where they snap onto your plugs, take them off and inspect them for tears or burn marks also.
Old 05-05-2013, 11:06 PM   #133
im going to have to do that tomarrow wen i get a chance
Old 05-07-2013, 12:23 PM   #134
ive been thinking could it be a bad silinoid dat dont give the signal to the starter
Old 05-07-2013, 02:34 PM   #135
A bad solenoid would not make your car shut off after it has started... All it does is send the signal to the starter for cranking.
Adam302gt is offline   Reply With Quote
Old 05-07-2013, 02:54 PM   #136
so wat do u think it could be
02:01 AM
