starting problem - Mustang Evolution
Old 04-11-2013, 12:32 PM   #1
moyhuerta91's Avatar
starting problem
Im having some starting problems in my 95 mustang 5.0. It crank and everything i could hear my fuel pump turn on but it wont start sometimes i dont now what it could be nd sometimes i will be driving it nd it shuts down. I hope i could get a lil help were to start.
moyhuerta91 is offline   Reply With Quote
Old 04-11-2013, 01:20 PM   #2
Do a quick google or forum search. When I had something similar there was a good "no start" checklist to isolate the problem. The dying while driving could be a bad PIP sensor in the distributor. Do hot or cold starts give you more of an issue? Many things to run down... TFI module, Fuel pressure, etc. Try to isolate before throwing a bunch if parts(money) at it.
Adam302gt is offline   Reply With Quote
Old 04-11-2013, 01:23 PM   #3
Can u give me a website to go to or anything if u have anything please nd thank u
Old 04-11-2013, 07:39 PM   #4
http://www.allfordmustangs.com/forum...checklist.html
Check this out.
Old 04-11-2013, 11:02 PM   #5
Its good information but wat my car does is that it stars but sometimes it wont start i will be cranking it and cranking nd it wont start but if i leave it for a bit wit out cranking for like abot 30 min or about an hour (estimate) it will start..
Old 04-12-2013, 05:58 AM   #6
Dion11197's Avatar
When's the last time you did or had a tube up? Basically speaking and engine won't start due to either no power, which if its cranking you don't have that problem, no spark (could be with worn out parts) or no fuel. A partially clogged fuel filter can cause issues as well as fuel pump screen/sock being gummed up. When the trash settles it's good. Also if you have low compression that could cause starting issues. Most of these are simple checks minus the fuel pump sock, that one you have to drop the tank, but if you've never let fuel sitting for too long or had water/rust in the tank you should be good there. Don't have too much info to go off of. Have you checked to see if you are getting spark and fuel when it's not starting? Just too many possibilities, gotta narrow it down. Could be a coil going bad to.
Dion11197 is offline   Reply With Quote
Old 04-12-2013, 08:41 AM   #7
Well i now its not.my fuel pump cuz i never run my car on low gas. I could be my fuel.filter because i havent changed dat for the longest. But last time i scand my car with a paper clip nd i got dis code. 212- ignition TECH signal was erratic (module/wiring) or SPOUT circuit fault- ignition systems
Old 04-12-2013, 08:11 PM   #8
Dion11197's Avatar
That would make sense, could be your ignition module then.
Old 04-13-2013, 01:34 AM   #9
Were is that located?
Old 04-13-2013, 11:26 AM   #10
Dion11197's Avatar
If you have a stock distributor it's the little module that has a plug near the cap (bellow) on the side of the distributor.
Old 04-13-2013, 11:29 AM   #11
Yea its stock i just changed the cap.and rotor. How much is dat part do u know.
Old 04-13-2013, 12:30 PM   #12
Dion11197's Avatar
I don't, I would think you could get it tested before you start throwing money at it. Maybe one of your local parts stores can check it for you.
Old 04-13-2013, 12:39 PM   #13
Ill check it out but i was looking for the ignition moduel but i couldnt find it i took pictures ill post them right now
Old 04-13-2013, 12:40 PM   #14
ID:	102251   Click image for larger version
Old 04-13-2013, 01:08 PM   #15
Dion11197's Avatar
I keep forgetting yours is newer, where the wires come out of the distributor, those should attach to the module. The older fox bodies have them attached to the distributor body, yours maybe close to the coil.
Old 04-13-2013, 01:31 PM   #16
Is their a diagram were i could check wee its located
Old 04-13-2013, 02:20 PM   #17
Dion11197's Avatar
I'm site there's gotta be something online.
Old 04-13-2013, 02:28 PM   #18
Alright thanks ill look it up see if i find anything
Old 04-13-2013, 02:48 PM   #19
On the 94-95, the ignition coil is that little black box thing in your third pic that the short spark plug wire goes to.
Old 04-13-2013, 02:56 PM   #20
Dion11197's Avatar
He's actually looking for the ignition module. I have an older fox so mine is part of the distributor. I see on his the wires come out of the distributor body and connect to a plug. I'm thinking if you trace those wires it would lead you to the ignition module, bit I'm not real familiar with the 94-95. Hopefully someone with a 94-95 can help out.
---------- Post added at 01:56 PM ---------- Previous post was at 01:54 PM ----------
Just did some research and it sounds like its under your air filter box.
Old 04-13-2013, 03:01 PM   #21
Now i now wat connection u guys r talking about i had replaced it its the one right under the air filter wen.u remove it
Old 04-13-2013, 03:03 PM   #22
Dion11197's Avatar
That should be the one, how long ago did you replace it?
---------- Post added at 02:03 PM ---------- Previous post was at 02:02 PM ----------
And was it having this same problem before you replaced it?
Old 04-13-2013, 03:09 PM   #23
I.chaged like 3 months ago. Yes it did but wen dat happend 3 months ago my car didnt want to start for nothing
Old 04-13-2013, 03:26 PM   #24
Dion11197's Avatar
Hmm, and the cap and rotor are new to?
Old 04-13-2013, 03:29 PM   #25
Yes but i was thinking of buying the whole distribiter
Old 04-14-2013, 08:12 AM   #26
Yeah, it is called the TFI module and it is under the air intake, but looks like you did that.
Old 04-14-2013, 09:01 AM   #27
Dion11197's Avatar
Have you checked your timing?
Old 04-14-2013, 10:23 AM   #28
No i havent but how could the timing get moved if i havent touchd the distributer
Old 04-14-2013, 01:45 PM   #29
Dion11197's Avatar
It shouldn't unless you have missing teeth on your distributor it slack in your timing chain that causes it to jump timing.
It's just easier to start with simple things to diagnose then jumping straight into part replacement.
Old 04-14-2013, 01:47 PM   #30
Oh ok i understand so i should get my timing checked.
Old 04-14-2013, 03:53 PM   #31
Dion11197's Avatar
I would, just toile site it's good. Timing being off can cause problems starting.
---------- Post added at 02:53 PM ---------- Previous post was at 02:52 PM ----------
Just to make sure it's good.
Old 04-14-2013, 04:39 PM   #32
How can i tell when the timing is off because i dont have a timing light
Old 04-14-2013, 04:43 PM   #33
91notchback's Avatar
Step 1: Buy or borrow a timing light...lol. Seriously, you'll have to have one man.
91notchback is offline   Reply With Quote
Old 04-14-2013, 06:33 PM   #34
Dion11197's Avatar
Yeah, you'll have to have one to check. And don't forget to pull the spout connector before.
Old 04-16-2013, 11:54 PM   #35
the spout connecter in the little fuse or something by the air filter right???
12:08 PM
