Stock cam - Mustang Evolution
Old 04-11-2013, 08:42 PM   #1
Ewokjax95's Avatar
Stock cam
So every time I get in this forum, I talk about cams and always change my mind. Well I've come up with something else. I've been entertaining the idea of trying to test the limits of a stock cam. I'm talking basically TF top end kit minus the cam. Possibly doing an S-trim and 5#s as well. I already have most of the supporting mods, meaning full bolt-ons. More than likely need injectors and thats it. I think this setup could easily push 400-425 at the crank. Anyone wanna weigh in?
Ewokjax95 is offline   Reply With Quote
Old 04-11-2013, 09:00 PM   #2
DerekJohnScott's Avatar
Do you mean physically test it? Until something breaks? In your own car?
DerekJohnScott is offline   Reply With Quote
Old 04-11-2013, 10:54 PM   #3
Ewokjax95's Avatar
Not talking about breaking anything. I don't really understand how you can break a cam. The idea is to just see how much power I can make on a stock cam. Would be cool if i could run high 11s on a stock cam IMO. It's just an idea though. I don't see very many Fox or sn95 cars running stock cam in my area.
Old 04-12-2013, 06:03 AM   #4
Dion11197's Avatar
It's doable, you just won't get all the power out of your combo without changing cams. There are turbo cars out there with stock cams that are well into the 11's. The trick is most of them turn up the boost to compensate for the lack of lift and duration of the cam, and you run into how much the stock bottom end will take.
Dion11197 is offline   Reply With Quote
Old 04-12-2013, 06:19 AM   #5
2300turboford's Avatar
May I ask why?
Old 04-12-2013, 08:04 AM   #6
FLAT BLACK GT's Avatar
Sleeper. People won't hear it beating the ground they won't l know what it's got until its too late.
FLAT BLACK GT is offline   Reply With Quote
Old 04-12-2013, 09:17 AM   #7
Ewokjax95's Avatar
Like he said. Somewhat of a sleeper and drivability. Also because i don't want to do the install lol. Too lazy.
Old 04-12-2013, 10:33 AM   #8
I won't lie though for a stock cam they do have somewhat of an aggressive note to them. I get asked all the time if I have an aftermarket cam in mine.
Old 04-12-2013, 11:25 AM   #9
Ewokjax95's Avatar
I know what you mean man. Btw, does anyone know the specs on the stock cam?
Old 04-12-2013, 12:01 PM   #10
VALVE LIFT DURATION LOBE CAM INT./EX. AT 0.050 IN SEPARATION Stock 5.0 0.444/0.444 210/210 115 Read more: http://www.mustang50magazine.com/sho...#ixzz2QH0IJPaB
Old 04-12-2013, 06:36 PM   #11
WhiteCobra94's Avatar
You can try 1.7 roller rockers on a stock cam will bump the lift up some!!
Old 04-12-2013, 07:23 PM   #12
91notchback's Avatar
Plus 1! About .030 lift.
91notchback is offline   Reply With Quote
Old 04-12-2013, 08:20 PM   #13
Dion11197's Avatar
+2, that'll also let you get some more air into those cylinders and take better advantage of that forced air!
Old 04-12-2013, 09:28 PM   #14
Didn't even think of that, as I am not much of a FI guy (yet) That makes damn good sense!!!
Old 04-13-2013, 11:17 AM   #15
Dion11197's Avatar
There's nothing like it! And the best part is the car is on kill mode all the time!!
Old 04-13-2013, 11:29 AM   #16
Ewokjax95's Avatar
Yep. 1.7r was the idea. What is the difference between TFs Twisted Wedge heads and the Track Heat heads? Price difference is 100$. Only difference i see is the Track Heats are rated to .600 lift while TWs are rated to .540 lift.
Old 04-13-2013, 01:43 PM   #17
Billymich's Avatar
+1 on 1.7 RR my thoughts exactly
« clutch | New Member »
12:04 AM
