Need help with idle problem - Mustang Evolution
Old 04-11-2013, 10:22 PM   #1
89notchbeast's Avatar
Hi fellas , I've been having a problem with surging idle in my 89 5.0 since I bought it about a month ago. I had several vacuum lines leaking and fixed those...I also changed IAC valve...seemed to fix it but always had trouble starting the car for the first time of the day...I had codes for check engine light so I got it checked and it pulled up throttle position sensor. Replaced it today and my idle was surging 900-3500 rpms any thoughts?
89notchbeast is offline   Reply With Quote
Old 04-12-2013, 06:08 AM   #2
Dion11197's Avatar
That's a serious surge. I've heard of guys having the problem, but a minor surge and they were able to solve it cleaning their mass air sensor. Not sure if it will help but it couldn't hurt. Hopefully someone else has had similar and can chime in. Do you have all stick mass air parts?
Dion11197 is offline   Reply With Quote
Old 04-12-2013, 08:31 AM   #3
I cleaned throttle body maf ...it's all stock .
Old 04-13-2013, 08:48 AM   #4
Jeff44's Avatar
2 things, I would either clean out or replace your EGR valve and replace your PCV valve. I had similar problems and after doing that, it helped.
Jeff44 is offline   Reply With Quote
Old 04-13-2013, 09:17 AM   #5
Today I'm changing timing chain and water pump cause timing chain is loose
---------- Post added at 10:17 AM ---------- Previous post was at 10:15 AM ----------
I'm hoping that's causing timing to be off and help..also I replaces EGR ..
Old 04-13-2013, 11:19 AM   #6
Dion11197's Avatar
Nice! Let us know the results.
Old 04-13-2013, 01:47 PM   #7
Billymich's Avatar
Set your timing on your Dizzy as well, good luck!
Old 04-13-2013, 02:46 PM   #8
Ok timing chain in...wasn't as hard as I thought..cars Definitely running better but I think the throttle Position sensor I bought is bad because when I unplug it the car runs and drives perfect now...I'm going to get a new tp Tomorrow and see what happens....I will keep you updated...thanks
Old 04-13-2013, 02:57 PM   #9
Dion11197's Avatar
Nice! That would make sense, but since you had just replaced it I was thinking it was something else.
Old 04-13-2013, 04:34 PM   #10
We"ll Find out tomorrow....I hope it's bad...lol
Old 04-13-2013, 04:35 PM   #11
Dion11197's Avatar
Me to!
Old 04-13-2013, 07:32 PM   #12
Ok just replaced Throttle position sensor For the second time is still running rough maybe it runs rough for a while after changing it so I'm going to take it for a ride and see what happens... If that don't work I'm going to disconnect my battery and reset the computer and hopefully that will help any ...
Old 04-14-2013, 02:02 AM   #13
Billymich's Avatar
Did you reset base idle?
Old 04-14-2013, 02:13 AM   #14
94 GT 5.0's Avatar
Same thing happened on my 96 vert i changed the EGR valve and EGR sensor and it fixed the problem. 10,000 miles later still no problem
94 GT 5.0 is offline   Reply With Quote
Old 04-14-2013, 09:22 AM   #15
Doing base idle reset in a few...let you know
Old 04-15-2013, 06:38 AM   #16
Jeff44's Avatar
Your PCV Valve may be clogged. I would change it out.
Old 04-18-2013, 04:56 PM   #17
Billymich's Avatar
What's the word>?
Old 04-20-2013, 01:10 AM   #18
Sorry guys been so busy with work...car is running good now but there is 2 noises I can't figure out...trying to post you YouTube when I do I will send the link..thanks again!
06:37 AM
