camshaft/stock heads - Mustang Evolution
Old 04-12-2013, 11:27 AM   #1
mustangmania91's Avatar
Ok I have a question for all you mustang gear heads........I have a 91GT, I wanna upgrade my cam mildly to a Ford Racing B303. Can I keep my stock heads/springs the same or will I need to upgrade those as well? Im trying to slowly upgrade the entire car but on a tight budget. Any help would be great!
mustangmania91 is offline   Reply With Quote
Old 04-12-2013, 01:04 PM   #2
91notchback's Avatar
Yes the stock heads are fine. You should be ok with your springs, unless they are wore out and weak.
91notchback is offline   Reply With Quote
Old 04-12-2013, 07:34 PM   #3
WhiteCobra94's Avatar
I would get a set of 1.6 rockers too
Old 04-16-2013, 05:05 AM   #4
3stangs's Avatar
^^^^stock rockers are 1.6. Unless you meant roller 1.6's
3stangs is offline   Reply With Quote
Old 04-16-2013, 09:47 AM   #5
Meant new roller rockers , Proform has the 1.6 pedestal mounted rockers from summit for $175
Old 04-16-2013, 09:55 AM   #6
3stangs's Avatar
And proform is pure junk. For a little more you can get comp cams
Old 04-16-2013, 02:21 PM   #7
Dion11197's Avatar
+1 on the stock heads being good.
I would recommend a spring upgrade so you don't have to worry about spring failure with the added lift.
Seeing how your on a budget, cleaning up the intake and exhaust ports in your heads and matching the port size to the gaskets will help you pick up a little more with the added airflow of the cam. That's something you can do yourself with the proper tools.
Dion11197 is offline   Reply With Quote
Old 04-16-2013, 09:46 PM   #8
Well I'm pushing good HP with my setup and no issues at all with the 1.7 Proform rockers
Old 04-17-2013, 02:54 AM   #9
3stangs's Avatar
You got lucky then. Some people don't have problems. Most do
12:00 PM
