Tranmision grind in reverse need help - Mustang Evolution
Old 04-12-2013, 11:23 PM   #1
Nick Proben's Avatar
94 gt 5.0 grinds when I'm Rollin back and letting out the clutch any idea what that could be and how soon should I get it checked out ?
Nick Proben is offline   Reply With Quote
Old 04-14-2013, 02:07 AM   #2
Billymich's Avatar
Its an unsynched gear, put it in fifth then reverse.
Old 04-14-2013, 03:27 AM   #3
It's not me, it's you.
primer2tone's Avatar
Also, check your fluid level if you haven't already.
It's not even the same car but I had the same problem. My '99 cavalier would grind only in reverse. I found that my shifter cable had a lot of play. The bushing that held the cable to the shift linkage had rotted away. A new cable was like $140 so instead, I filled the void of the bushing with zip ties. It worked great for years.
» Members Mustangs
none
okfoz
Manfred
bigmac3
Add your Mustang
03:58 PM
