Timing - Mustang Evolution
Old 04-13-2013, 11:33 AM   #1
Minus2380's Avatar
Timing
On a 1995 mustang gt, where does the notch have to be on the distributer (roughly). I don't have a timing light and I have been trying to do it by ear but it will either start pinging if I get to close to the Lil clamp or if its too far away it doesn't have the "git up" at full throttle. Please help!!!!
Minus2380 is offline   Reply With Quote
Old 04-13-2013, 01:45 PM   #2
Billymich's Avatar
No good way to do it without experience or a timing light, are you 91+ octane, makes a big difference. Are all your spark wires routed correctly? is the cap on correctly?
Old 04-13-2013, 03:37 PM   #3
Minus2380's Avatar
Yea. It was working fine till I replaced my distributor and forgot to mark it.
Old 04-14-2013, 11:05 PM   #4
Billymich's Avatar
You probably put it in a tooth or two off, you could try minor adjustments two that.
Old 04-15-2013, 10:06 AM   #5
DustyStang306's Avatar
If I were you I'd buy a timing light so you don't hurt the timing chain I never move my with out the timing light just in case
DustyStang306 is offline   Reply With Quote
Old 04-15-2013, 10:21 AM   #6
Boomdizzle's Avatar
Yeah you def need a timing light to get it dialed in correctly. You may be able to even rent one from Auto zone
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 04-15-2013, 10:53 AM   #7
For tuning just bought one if you run 91+ octane it helps to get a few ponies out of it the lights worth ever $$$ trust me you will use it more then once I use my at the track alot in the summers to see what the motor likes best under higher octane fuels
---------- Post added at 11:53 AM ---------- Previous post was at 11:49 AM ----------
An if your hearing pining that's not to good for the motor an means your timing defiantly off an is probably not to good for it...
Old 04-15-2013, 06:16 PM   #8
Minus2380's Avatar
Right on!!! Thanks guys!!!
12:04 AM
