PLEASE HELP battery problem - Mustang Evolution
Old 04-17-2013, 01:36 PM   #1
Nick Proben's Avatar
I have a 95 gt that when it sits in my garge over night and I go to start it in the morning the battery is complete dead and won't start but when I jump it it start perfect. None of the doors are open and all power stuff is off so there is no power being drawn from the car so I don't understand why it's doing this it would be greatly appreciated it anyone could help me out thanks.
Nick Proben is offline   Reply With Quote
Old 04-17-2013, 01:45 PM   #2
Brett Greene's Avatar
Test the voltage of the battery. Sounds like an alternator problem more than likely.
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 04-17-2013, 01:48 PM   #3
91notchback's Avatar
Sounds like you got a power draw somewhere. Time to start chasing wires! fun fun....
---------- Post added at 02:48 PM ---------- Previous post was at 02:45 PM ----------
The alternator wouldn't be causing a draw when nothing's on. If your alternator is bad, it will just be running off battery when everything is on. Best way I can word it.
91notchback is offline   Reply With Quote
Old 04-17-2013, 01:55 PM   #4
Ok thanks I'm gunna check the alternator and fuses and see what if that works thanks
Old 04-17-2013, 01:59 PM   #5
TruChris's Avatar
I had this problem with my 98 cherokee i went to autozone and they said it was alternator. Got a new one an perfect! Try autozone to check if its batter or alternator if neither than its a power drain.. Hope that helped dont no much but that
TruChris is offline   Reply With Quote
Old 04-17-2013, 02:06 PM   #6
Yes sir. Start small! I'm not sayin the alternator isn't a possibility by any means. Just seems weird to me that it happened while nothing was running. That's usually not the calling card of a bad alternator.
Old 04-17-2013, 04:09 PM   #7
Jon517's Avatar
I had that happen to me and my Horn relay got stuck on but my horn dosent work to begin with so I Hurd no sound. If your horn works you'll hear it going off. Hit your horn to make sure it works. If it dosent than check your horn relay. But it also could be a dead battery cell
Jon517 is offline   Reply With Quote
Old 04-17-2013, 04:19 PM   #8
That would fall into power drain. It just don't sound like a bad alt to me. I've been wrong before!! Let us know man!!
02:03 PM
