Need help with clutch problem!! Please - Mustang Evolution
Old 04-20-2013, 05:19 PM   #1
We'll I put new clutch in my 95 gt mustang and when I put everything back together it will not engage it is not tight at all either I jacked the car up and I can move the clutch fork by hand I just don't know if I did something wrong when I put the clutch In, please help is there anything I can do to try to test it or figure out what the problem is??? Please help!!!
Mikebhuh is offline   Reply With Quote
Old 04-20-2013, 05:23 PM   #2
BatmanUriah's Avatar
Is your slave cylinder hooked up? I've never changed a clutch on that car, but if you took it off to change the clutch, maybe you forgot to put it back.
BatmanUriah is offline   Reply With Quote
Old 04-20-2013, 05:46 PM   #3
rick9550's Avatar
No slave cylinder on a 95. Straight cable clutch.
What happens when you push the clutch down? Does it sit on the floor? Or do you feel tension?
You probably need to adjust the cable. Lift up on the clutch pedal to tighten the cable. Unless you have an aftermarket. Them you should be able to adjust the cable from the firewall.
2011 GT Premium Black on Black, Eibach Sportline, Eibach Camber Bolts, BMRAdjustable Pan-hard bar, 19 x 9 Replica Boss 302 Laguna Seca, 275/35-19, GT/CSFront Fascia, C&L CAI, SCT SF3 w/ Bama Tune, Bassani Axle backs.
rick9550 is offline   Reply With Quote
Old 04-20-2013, 06:15 PM   #4
We'll I jacked the car up and took the cable off the clutch fork and I can move the clutch fork back and forth, idk if that is good... But when I put it all back together the cable was loose when I hooked it and if I pull up on the pedal the cable comes off it has no tension!!
Old 04-20-2013, 06:28 PM   #5
rick9550's Avatar
Clutch fork will move with the cable off. That is normal. Take the cable out completely and make sure it's not broke. Check the clutch quadrant under the dash to see if something broke there as well.
If its not either of those you may have to take the trams out again and check the throw out bearing or pressure plate. If the clutch plate was misaligned may cause something like this but it would have been unlikely that you could of matched up the input shaft.
You could shine a flashlight in where the clutch fork is and see if you notice any of the pressure plate teeth depressed.
---------- Post added at 07:28 PM ---------- Previous post was at 07:27 PM ----------
Did you instal a new throw out bearing with the new clutch? Check to make sure that is not backwards.
Old 04-20-2013, 06:43 PM   #6
Yea I put a new throw out bearing in and ok I'm ganna try to check the cable and stick a light In to c if there is any problems thank u all I will let u know if any of this is the problems thank u all!!
Old 04-21-2013, 06:48 AM   #7
rick9550's Avatar
Find anything?
Old 04-21-2013, 08:37 AM   #8
Yea I jacked the car up and I couldn't find anything up in there so I unhooked the clutch cable and noticed I could move the fork back and forth..also I could pull back and push up on the fork at the same time and when I push up and down on it it kinda feels like it goes into a groove then I put the cable back on and it worked its still real loose but It did work...and it has a bbk adjustable cable but as far as adjustment goes should I jut try to adjust it on the fork or take it and adjust it somehow???
Old 04-21-2013, 08:39 AM   #9
Old 04-21-2013, 08:49 AM   #10
rick9550's Avatar
You should have two ways to adjust the cable. There should a quadrant under the dash where the cable attaches with teeth. You can move the cable to different teeth for major adjustments and you should have something attached to the firewall that will give you a finer adjustment. Should be like an aluminum housing that can screw in or unscrew to tighten it loosen. Should be able to lock it down after you get it adjusted
---------- Post added at 09:49 AM ---------- Previous post was at 09:48 AM ----------
Pretty sure you can't adjust it from the fork side.
Old 04-21-2013, 10:47 AM   #11
Ok I thought I had it but when I pull down on the clutch fork it grabs but after hitting the clutch about 5 times it pops out of place again any ideas on what the problem could be??? It works fine when I pull the fork down but when it is pushed up it dosent grab...
Old 04-21-2013, 11:00 AM   #12
rick9550's Avatar
The cable pops off from the clutch fork side? Is there a way to fasten the cable to the side of the tranny to keep it from moving? I remember there is a strap that ties it to the inner fender but don't remember if there is another one for the tranny.
Old 04-21-2013, 11:05 AM   #13
No the cable stays on, it's just the fork itself. I can push it up and down and when I pull it down it grabs and pushes the clutch in but after about five times hitting the clutch the fork goes back up and will not grab anymore
Old 04-21-2013, 11:12 AM   #14
rick9550's Avatar
There is should be a clip on the fork that slides on to a pivot ball. Sounds like maybe the fork is not on it or the clip broke or the pivot ball is messed up. That should be attached to the bell housing.
Old 04-21-2013, 11:14 AM   #15
So I'm prolly ganna have to drop the tranny to get to it??
Old 04-21-2013, 11:16 AM   #16
rick9550's Avatar
Maybe. The fork may pull out enough to get the clipped part over the pivot ball. You should be able to see if that is the issue with a flashlight like the pic you attached.
Old 04-21-2013, 11:18 AM   #17
Thank u Rick I am ganna get me a good light to c if I can see the ball
Old 04-22-2013, 06:09 AM   #18
rick9550's Avatar
Get it worked out?
Old 04-23-2013, 05:47 PM   #19
Not yet I am ganna try to find out this weekend ill let u know thank u
Old 04-25-2013, 03:48 PM   #20
I got off work today an got a inspection mirror and found my problem, the two clips at the top of the fork only one is on the backside of the ball the other is not around the ball I there any way to pop back in place without tranny drop??? Any help thank u!
Old 04-25-2013, 06:27 PM   #21
rick9550's Avatar
Not sure. I would think you may be able to pull the fork out a bit and see if you can get it back in place. Someone else may have to chime in here.
Old 04-25-2013, 07:09 PM   #22
We'll thank u Rick I tried to get it with a flat screwdriver and couldn't get it but I am ganna try to bend something so I can get to it ill let u know if I have any luck this weekend!!
Old 04-28-2013, 08:14 AM   #23
rick9550's Avatar
Update? Did you end up having to drop the tranny to get the fork back on the pivot ball?
03:33 PM
