89 mustang to slow help - Page 2 - Mustang Evolution
Old 05-06-2013, 08:36 PM   #36
Dion11197's Avatar
Yeah, 13.9 is definitely better. Now to dial in his combo.
Dion11197 is offline   Reply With Quote
Old 05-07-2013, 05:30 AM   #37
DustyStang306's Avatar
Ye that's what I was thinking I'm thinking it still should be a little faster I'm guessing he's using gt40 heads then
DustyStang306 is offline   Reply With Quote
Old 05-07-2013, 06:09 AM   #38
Dion11197's Avatar
Even still with a cam and all I would think low 13's.
Old 05-07-2013, 08:17 AM   #39
93slowstang's Avatar
Sounds more like stock heads. High 12s low 13s with gt40 heads.
Old 05-07-2013, 10:38 AM   #40
Haha ye iv seen e7s with port work do high 12s haha I'm thinking your right on that one put a bottle in her in start put down some high 11 to mid 11
Old 05-07-2013, 01:07 PM   #41
Jcstang's Avatar
Yeah I think he should be doing less but the track down here sucks
---------- Post added at 02:07 PM ---------- Previous post was at 02:05 PM ----------
His heads are aluminum just haven't took the time to check what they really are
Jcstang is offline   Reply With Quote
Old 05-07-2013, 04:24 PM   #42
Where I am we got the one of the worst track in Ontario but theres no guys I know running h/c/I an only getting a 13.9 there hitting like low 13s an high 12s even a few in the high 11 what tires was he running an what size was there lots of wheel spin? An what gears he in when he's just passes the 1/4 mark? I'm just trying to see why it could be that slow I run faster the that with a stock 302 with a b303 cam an a typhoon upper an lower with port work an the e7s that were on it were ported a bit to my best time was 13.4 with slicks a I had 3:73 gears at that time
Old 05-07-2013, 07:43 PM   #43
Jcstang's Avatar
Yeah he has 3.73 and he ran with drag radials some wheel spin
---------- Post added at 08:43 PM ---------- Previous post was at 08:41 PM ----------
No way the track out here if you loose expect to have a broken windshield half way the track it's unleveled oh and have to be careful with a pothole
Old 05-12-2013, 12:33 PM   #44
Tkcobrasvt's Avatar
You need to pull your mass air sensor completely out of the mass air housing using the special torque bit with the hole in the middle and get a Q-tip with rubbing alcohol and clean very lightly the mass air filament. I did this on my 95 cobra the day I got it and instantly gained and extra 40% power. My cobra wouldn't even go 90mph in 3rd gear. Try this I bet it will help tremendously. It should take no more then 4 min to do. Nothing to loose!
Tkcobrasvt is offline   Reply With Quote
Old 07-08-2013, 02:02 PM   #45
Jcstang's Avatar
Now car feels ok but not fast enough but the reason I'm here again is the car is overheating and wanted to know if swapping pulleys affect the temp and if it does how much more
12:34 AM
