89 mustang to slow help - Mustang Evolution
Old 04-21-2013, 10:29 PM   #1
Jcstang's Avatar
Alright here I go a body of mine has an 89 mistang 5.0 and we can't get 1/4 mile times less than 15.3 what could be the problem does a Dyno tune work for that year model
---------- Post added at 11:29 PM ---------- Previous post was at 11:28 PM ----------
Sorry buddy
Jcstang is offline   Reply With Quote
Old 04-21-2013, 10:38 PM   #2
91notchback's Avatar
Sorry buddy
Start spending money and turnin wrenches!lol HCI would crank on your times...
---------- Post added at 11:38 PM ---------- Previous post was at 11:37 PM ----------
And rear end gears...
91notchback is offline   Reply With Quote
Old 04-21-2013, 10:39 PM   #3
Jcstang's Avatar
Car has everything I could imagine
Old 04-21-2013, 10:40 PM   #4
93slowstang's Avatar
+1.
Old 04-21-2013, 10:40 PM   #5
Jcstang's Avatar
Gears heads intake tko tranny 4:10 gears
Old 04-21-2013, 10:43 PM   #6
WWHHHAAATT??? At a 15sec 1/4???
---------- Post added at 11:43 PM ---------- Previous post was at 11:42 PM ----------
Specs please.
Old 04-21-2013, 10:48 PM   #7
Jcstang's Avatar
I know it has 4:10 hears at rear end heads I really don't know the brand it has a steeda 18 cam stage 2 clutch comp cams 1.6 lifters cobra intake manifold if I'm correct 75 mm throttle body MAF. Calibrated for bigger injectors
Old 04-21-2013, 11:00 PM   #8
A stock fox runs about a low 14/high 13. I've never heard of a modded one runnin UNDER stock. You got me...
Old 04-21-2013, 11:03 PM   #9
Driver mod...???
Old 04-21-2013, 11:04 PM   #10
Originally Posted by 93slowstang View Post
Driver mod...???
my next answer...
Old 04-21-2013, 11:09 PM   #11
Jcstang's Avatar
That's what I thought at first everyone drove the car 15.6 and up I hit a 15.3 and it's weird cause I have another buddy with a almost stock 5.0 and hit a 15.0 with regular tires what could it be
Old 04-21-2013, 11:14 PM   #12
Hell...ya got me! I've gotta friend that drove a STOCK civic hatch 1.5 at 15.3. Something's up...
Old 04-21-2013, 11:19 PM   #13
Jcstang's Avatar
Yeah I can't seem to find the problem
Old 04-21-2013, 11:24 PM   #14
I'm in the middle of a WORKED gt40 build with supporting mods, and I'm expecting high 12s. Does he have all supporting mods?
---------- Post added at 12:24 AM ---------- Previous post was at 12:23 AM ----------
High12s/LOW13s
Old 04-21-2013, 11:27 PM   #15
Jcstang's Avatar
Yeah
Old 04-21-2013, 11:30 PM   #16
Yeah
---------- Post added at 12:30 AM ---------- Previous post was at 12:29 AM ----------
I can't say ****!??
Old 04-22-2013, 02:49 AM   #17
tc x 4's Avatar
Do a compression check, something is not right. Bad valve job is my guess.
Old 04-22-2013, 05:53 AM   #18
Dion11197's Avatar
Yeah, something is wrong! Lol
See if you can get a spec in the heads too! If he's got an over sized head that flows too much it can actually hurt performance. And I'm wondering if the head and intake ports are matched??
There could be engine problems..... Have y'all pulled the plugs to see how it's running?
I'm thinking either there's something really wrong with the engine combo or it's just REALLY tired.
Dion11197 is offline   Reply With Quote
Old 04-22-2013, 08:28 AM   #19
Jcstang's Avatar
It's bored over .40 just rebuilt but before the button end got fixed that valves were hitting in the old pistons I don't know if the mechanic checked the heads
---------- Post added at 09:28 AM ---------- Previous post was at 09:27 AM ----------
BTW how could I know what kind of heads he's got they should have some kind of a serial # right
Old 04-22-2013, 08:50 AM   #20
Dion11197's Avatar
They should, usually they are marked.
I'm wondering if the mechanic fixed everything. Sometimes if there's serious piston to valve contact, the valve gets bent. As mentioned earlier, I think a compression test is needed. I would also check all the plugs to see how it's running.
Does the engine sound on when running? I'm also wondering if its running on all cylinders.....
---------- Post added at 07:49 AM ---------- Previous post was at 07:49 AM ----------
Does it sound ok when running?
---------- Post added at 07:50 AM ---------- Previous post was at 07:49 AM ----------
Any misses or sputters? And does it seem to pull all the way through the RPM range or does it fall off?
Old 04-22-2013, 11:23 AM   #21
Jcstang's Avatar
Yeah engine sounds nice and strong but doesn't run strong it has a mean take off but that's it
---------- Post added at 12:23 PM ---------- Previous post was at 12:22 PM ----------
Only when cold on initial startup backfires through the intake when it warms up it sounds ok
Old 04-22-2013, 11:27 AM   #22
Timing sounds off if its backfiring through the intake. May possibly have an issue with the fuel system as well.
Old 04-22-2013, 11:31 AM   #23
tc x 4's Avatar
Yep
Old 04-22-2013, 11:40 AM   #24
Jcstang's Avatar
Fuel problem it did have a bad injector and all of them were swapped afterwards
Old 04-22-2013, 11:44 AM   #25
You definitely need to check the base timing, if its good then you need to check the fuel pressure and make sure it's around 40# with the vacuum line pulled at idle.
Old 04-22-2013, 11:46 AM   #26
Jcstang's Avatar
Ill check after work that plus compression
Old 04-22-2013, 02:57 PM   #27
Dion11197's Avatar
+1
Old 04-28-2013, 08:29 AM   #28
Dion11197's Avatar
Did you find out anything?
Old 04-28-2013, 01:24 PM   #29
Jcstang's Avatar
Nope not yet my buddy ended up taking it to a performance shop but once he gets it back ill post on what they found
Old 04-28-2013, 01:42 PM   #30
Dion11197's Avatar
Cool.
Old 04-30-2013, 12:31 PM   #31
Naut is offline   Reply With Quote
Old 05-05-2013, 08:59 PM   #32
Dion11197's Avatar
Anything new?
Old 05-06-2013, 01:15 PM   #33
Jcstang's Avatar
Yes the mechanic said it was a main wire harness (salt and pepper connector) car ran a 13.9 yesterday
Old 05-06-2013, 06:22 PM   #34
DustyStang306's Avatar
That's a little better haha what heads is he running?
DustyStang306 is offline   Reply With Quote
Old 05-06-2013, 07:13 PM   #35
Jcstang's Avatar
I really don't know
02:57 AM
