1987 mustang - Mustang Evolution
Old 04-22-2013, 09:41 PM   #1
1987mustanglx50's Avatar
1987 mustang
Does anyone no what modifications would I need to to for me to install a long/big block 5.0 engine to my 1987 mustang lx 5.0
1987mustanglx50 is offline   Reply With Quote
Old 04-23-2013, 07:10 AM   #2
rick9550's Avatar
When you say big block, do you mean a 351?
2011 GT Premium Black on Black, Eibach Sportline, Eibach Camber Bolts, BMRAdjustable Pan-hard bar, 19 x 9 Replica Boss 302 Laguna Seca, 275/35-19, GT/CSFront Fascia, C&L CAI, SCT SF3 w/ Bama Tune, Bassani Axle backs.
rick9550 is offline   Reply With Quote
Old 04-23-2013, 07:25 AM   #3
I attached a picture it's a 5.0 long block
Old 04-23-2013, 07:44 AM   #4
Dion11197's Avatar
That looks like just a crate 5.0 motor. By long block they mean it comes with heads and mostly assembled.... A short block is minus heads, just the block and rotating assembly.
---------- Post added at 06:44 AM ---------- Previous post was at 06:43 AM ----------
Should be a direct replacement.
Dion11197 is offline   Reply With Quote
Old 04-23-2013, 07:46 AM   #5
Nice thank you for your help really much appreciated
Old 04-23-2013, 07:47 AM   #6
Dion11197's Avatar
Not a problem!
Old 04-23-2013, 08:07 AM   #7
rick9550's Avatar
You should make sure whether it is a solid roller motor versus a hydraulic roller motor though. Not a direct replacement if yours isn't the same. You may need lifters. Can't tell from the pic but I would assume that it does not come with an intake.
---------- Post added at 09:07 AM ---------- Previous post was at 09:04 AM ----------
Also see what heads are on it. E7TE were the stock heads that came on your car I believe. But they were different on earlier years with less flow.
Old 04-23-2013, 08:08 AM   #8
Dion11197's Avatar
Good point, hard to tell from the pic but look in the description, should tell you that info as well as what applications it should be used for.
Old 04-23-2013, 08:18 AM   #9
Ok i will check that thanks for your help
11:43 PM
