Help? Won't run! - Mustang Evolution
Old 04-23-2013, 06:09 PM   #1
mustang90ace's Avatar
Help? Won't run!
So, I just did my 5 lug swap on the front (I know that didn't have anything to do with it). But when I got it off the jack stands, it'll crank but it dies when I let the clutch out sometimes even with the clutch still engaged. It cranks, but won't run. Don't know what the problem is. It'll run sometimes when I'm pulling the steering wheel towards me, but only sometimes. Thanks.
mustang90ace is offline   Reply With Quote
Old 04-24-2013, 06:44 AM   #2
rick9550's Avatar
Check your basics first. You getting fuel pressure?
2011 GT Premium Black on Black, Eibach Sportline, Eibach Camber Bolts, BMRAdjustable Pan-hard bar, 19 x 9 Replica Boss 302 Laguna Seca, 275/35-19, GT/CSFront Fascia, C&L CAI, SCT SF3 w/ Bama Tune, Bassani Axle backs.
rick9550 is offline   Reply With Quote
Old 04-24-2013, 06:52 AM   #3
Stangfan21's Avatar
The big three are fuel,spark and air start with whatever is easiest for you but it sounds like a fuel issue
Stangfan21 is offline   Reply With Quote
Old 04-24-2013, 07:24 AM   #4
It runs if i stay on the gas, as soon as I let off it dies. I hear the fuel pump, and the relay but as far as pressure at the regulator I don't know. How would I check?
Old 04-24-2013, 07:41 AM   #5
Stangfan21's Avatar
There is a schrader valve on your fuel rail to hook up a gauge and check fuel pressure I don't know the spec but you can look it up its an easy process to do
Old 04-24-2013, 07:49 AM   #6
Ok, thanks. If its not raining when I get off I'll see what I can do.
Old 04-24-2013, 07:02 PM   #7
Ok, so I have fuel. I started it up and it died, so after that I started it up again and held the gas down to keep it running. I took it down the road and back about a half mile when I got back it idled perfectly. So, what now?
Old 04-24-2013, 07:11 PM   #8
Stangfan21's Avatar
Do you have any aftermarket parts that have to do with fuel or spark
Old 04-24-2013, 08:30 PM   #9
Negative, just your basic preventative maintenance. New fuel pump, relay, still has stock ignition except plugs, wires.
Old 04-24-2013, 08:36 PM   #10
Stangfan21's Avatar
If your getting good fuel pressure and spark either you have a issue with getting air like the MAF or throttle body sounds like its an intermittent issue those are hard to track
Old 04-25-2013, 05:16 AM   #11
Ok, how do I try to come at this then? I have never had a problem like this, everything has always been simple for the most part.
Old 04-25-2013, 05:53 AM   #12
Dion11197's Avatar
I would start simple.... You know you have spark and fuel... It always starts but will die sometimes after idle. I would clean the MAF sensor and check TPS voltage. Could be the TPS sensor going bad.
Dion11197 is offline   Reply With Quote
Old 04-25-2013, 07:21 AM   #13
Ok, thanks. I'll clean my MAF, and check my TPS voltage today and see how that is. May not be able to get to it today though.
Old 04-25-2013, 09:46 AM   #14
Dion11197's Avatar
Yeah, I would start there. Let us know how it works out.
Old 04-25-2013, 09:49 AM   #15
Will do, thanks.
Old 04-26-2013, 11:14 AM   #16
I have a quick question. How do you go about checking the TPS voltage?
Old 04-26-2013, 12:04 PM   #17
92coupe's Avatar
I had a similar problem on my old fairmont, it would die at lights but would fire right back up until finally it would crank forever and wouldn't start. It ended up being the ignition control module for me.
92coupe is offline   Reply With Quote
Old 04-26-2013, 12:33 PM   #18
Hmmm, I'll have to check that somehow too.
Old 04-26-2013, 12:36 PM   #19
Dion11197's Avatar
You use a voltmeter, the voltage should be set to .98-.99
Old 04-26-2013, 12:46 PM   #20
Which write do I check? Red, right?
Old 04-26-2013, 12:55 PM   #21
Dion11197's Avatar
I can't remember which for sure, but if you test it with the voltmeter, one is ground one should show 4 volts and the other will show your voltage when key is turned on. Loosen the two screws slightly and rotate to adjust of needed and don't forget to retest.
Old 04-26-2013, 12:59 PM   #22
Ok, great. Thanks for the help.
Old 04-26-2013, 01:00 PM   #23
Dion11197's Avatar
The wire colors vary between year models, with the throttle closed it should be between .98 and 1 volt. Then you can test the sensor by opening your throttle and should see a steady increase to wide open throttle to roughly 4 volts. If your voltage suddenly drops off while opening, you more than likely have a bad TPS.
Old 04-26-2013, 02:41 PM   #24
Ok, thanks for your help. Gonna see what I can do.
Old 04-26-2013, 03:10 PM   #25
Dion11197's Avatar
No problem, just hope it helps your problem
Old 04-26-2013, 03:30 PM   #26
Got it, I feel like an idiot! Went to check my TPS, bumped my CAI pipe and it fell out of the sleeve to the throttle body. Snugged everything back up. Busted right off.....lol. The simple stuff right.
Old 04-26-2013, 04:40 PM   #27
Dion11197's Avatar
Yup! Very nice!! Lol sometimes it is the simple stuff! I like it when it's simple and you don't have to spend any money!
Old 04-26-2013, 04:45 PM   #28
Yeah, I do too. Just kinda makes you feel like a boob....lol
Old 04-26-2013, 04:46 PM   #29
Dion11197's Avatar
Hahaha, oh well, we've all been there!
Old 04-26-2013, 04:49 PM   #30
Lol, thanks for all your help!
Old 04-26-2013, 04:55 PM   #31
Dion11197's Avatar
Hahaha, no problem! Well I guess of nothing else, you now know how to set your TPS voltage.
Old 04-26-2013, 04:57 PM   #32
Yeah.....lol
Old 04-26-2013, 05:02 PM   #33
Dion11197's Avatar
Here soon I'm gonna be undertaking a gt40p head and explorer intake swap on my 86, as well as doing the mass air conversion with cold air intake, bigger TB and EGR. So I'm sure you'll see plenty of tech questions from me posted soon, lol.
Old 04-26-2013, 05:19 PM   #34
Lol, I'll do what I can to help. I'm about to jump into a GT40 head/intake with a TFS cam on mine with a bigger TB, etc. with a little something extra around 8 lbs or so...
Old 04-27-2013, 07:07 AM   #35
Dion11197's Avatar
Nice! In my opinion there's only one option for a power adder, and that's forced induction!
01:05 PM
