Gt40 intake!!! - Mustang Evolution
Old 04-26-2013, 08:11 AM   #1
Adogg's Avatar
Gt40 intake!!!
So I just purchased these from another member on here thank you very much to that member. Just thought I would share it with the rest of you. Has anyone put one of these on a 94 gt? Do I need anything special other then a new elbow? And does anyone have any ups on installing it? Thank you for all help
Don't hate....... appreciate
Old 04-26-2013, 08:13 AM   #2
Adogg's Avatar
More pics
ID:	104316   Click image for larger version
ID:	104318   Click image for larger version
Old 04-26-2013, 12:55 PM   #3
Adogg's Avatar
Really no one?
Old 04-26-2013, 12:58 PM   #4
Yes u will need a special fitting to disconnect the fuel line , but other then that its pretty strait forward , just make sure it's all clean and scraped to flush install it , use the blue silicone on this so if it gets in the intake runner it will do no damage , good luck and happy install
Tonyj is offline   Reply With Quote
Old 04-26-2013, 01:04 PM   #5
Adogg's Avatar
You know where I can get this special fitting? And what kind of gasket set will I need?
Old 04-26-2013, 01:16 PM   #6
WhiteCobra94's Avatar
And make sure nothing falls down into the motor when your remover the intake base
Old 04-26-2013, 01:31 PM   #7
Dion11197's Avatar
The tool you'll need to disconnect the fuel line can be purchased at any auto parts store or tool store.
Dion11197 is offline   Reply With Quote
Old 04-26-2013, 02:20 PM   #8
Adogg's Avatar
Will I need any special gaskets if so which ones I wanna replace them all when Iam in there
Old 04-26-2013, 03:09 PM   #9
Site Sponsor
Sponsor
AMWill's Avatar
OP,
Make sure to clean up all of the surface extremely well. If you have to second guess yourself, keep cleaning! The only other thing you should need is RTV sealant and the proper torque sequence. Everything else l can think of was already mentioned..
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 04-26-2013, 03:48 PM   #10
Adogg's Avatar
Thanks everyone for the help if anyone has any more tips let me know!! Do you guys think I should upgrade my tb with this intake?
Old 04-26-2013, 04:12 PM   #11
Dion11197's Avatar
I would, take advantage of the extra airflow. If I'm not mistaken you can put up to a 70mm on it without porting.
Old 04-26-2013, 04:14 PM   #12
Adogg's Avatar
Yea it's 70 I think the intake elbow Iam get is 70 mm to is that a good size?
Old 04-26-2013, 04:15 PM   #13
Dion11197's Avatar
That's what going with on mine. I've got the explorer intake and gt40p's waiting to go on.
Old 04-26-2013, 07:50 PM   #14
Adogg's Avatar
Nice man sounds like a good build looks like 70 mm the way to go you going to get yours dynoed
Old 04-27-2013, 08:10 AM   #15
Dion11197's Avatar
Maybe at some point. Right now I still have the stock 86 block which has flat top pistons with no valve relief, so I can't really do a cam swap to really see more power out of the heads and intake. I'm gonna keep shopping for a complete explorer motor and use that for my more serious build.
---------- Post added at 06:10 AM ---------- Previous post was at 06:09 AM ----------
At least until I can save up for a really stout block with forged internals.
Old 04-27-2013, 08:58 AM   #16
Adogg's Avatar
Nice man that sounds sick. I have the intake and lts in mail!! Iam also thinking about selling a flywheel I purchased and buying a tb and gears. Are you running gears and a upgraded flywheel?
Old 04-27-2013, 09:14 AM   #17
Dion11197's Avatar
Not yet, I'm gonna go with some 4.10's on this one. It's going to be a N/A car for a while before I can finally afford the supercharger kit I want. I know a guy who's got an 86 hatch that's been MAF converted running a stock explorer motor minus bolt ons and a cam and he's turning 11's in the quarter and put down something like 340rwhp. Pretty potent for such a mild combo. And I want to say the motor has close to 100k on it.
Old 04-27-2013, 09:24 AM   #18
Adogg's Avatar
Damn that car is badass!!!! And is yours an auto or 5speed? I was thinking 4.10 to but people say there overkill for a 5speed and gas mileage? And if your looking to upgrade your flywheel I will be posting my new one for sale. Your going to need it if your pushing those kind of numbers lol!
Old 04-27-2013, 10:21 AM   #19
Dion11197's Avatar
Right! Yeah, mine's a 5 speed. Teu actually do pretty good seeing how low geared 5th gear is.
Nice, I'll keep the flywheel in mind!
Old 04-28-2013, 11:05 PM   #20
havhammer's Avatar
The gasket set you need to get is for the 1993 cobra motor or 5.0l explorer motor. I have the fel pro part number if you need. Also get black rtv and use that to seal the lower intake to cylinder heads. If the set comes with cork end pieces , I don't use them and just use a bead of rtv on the ends instead - never had leakage issues. Good luck
havhammer is offline   Reply With Quote
Old 04-29-2013, 06:39 AM   #21
Dion11197's Avatar
+1 on the RTV sealant, always works like a charm.
I'll Pm you some other info for the gaskets.
Old 04-29-2013, 07:28 AM   #22
mustangmania91's Avatar
Any or most auto stores carry intake gasket sets. Usually sold complete. Always use the blue rtv sealant. Fairly easy to install. Good luck!
mustangmania91 is offline   Reply With Quote
Old 04-29-2013, 10:45 AM   #23
Bane-'s Avatar
just get the gaskets for the year explorer it came out of and call it a day. Does it have the internal or external egr?
Old 04-29-2013, 11:01 AM   #24
Adogg's Avatar
Thanks guys for the help and I just purchased a gasket set for the explorer intake. And it has an egr spacer on the intake so does that mean it has and external egr system? And if it has to be deleted that is not a problem. All I need now is intake elbow and possibly a new tb I wish I could find a used one for my car.
Old 04-29-2013, 12:13 PM   #25
havhammer's Avatar
What size t.b.?
Old 04-29-2013, 12:26 PM   #26
If its going on a 94/95 then the intake has nothing to do with the EGR, its all external. If you get an adapter elbow it'll have the EGR provisions on it.
TB... there are a million threads on this. The intake opening is 70mm so it makes sense to some ppl to use a 70mm TB. With that said a smaller TB will increase velocity and if the car is still using the junk E7 heads you might want that velocity because the heads flow dick and won't pull any more air through a bigger TB anyway but the bigger TB will decrease velocity and therefore power. Lots of 94/95 Cobra guys (which came with the stock 60mm TB that every other 5.0 in 94/95 got) don't upgrade the TB until they put a supercharger on it or get the intake ported. No need.
Old 04-29-2013, 03:27 PM   #27
Adogg's Avatar
I was looking at 70 mm tb but it looks like there is no need to spend my money. The Intake is mildly ported but yes Iam still using the stock heads. And yes the intake does has something to do with the egr cause if the Intake had the egr built in and my car uses an external system those to things are conflicting and the one on the Intake need to be plugged or something I believe.
Old 04-29-2013, 06:13 PM   #28
Bane-'s Avatar
yea some explorer intakes had either internal or external. the external (which you have) has the same setup as what you originally had with it on a spacer by the throttle body. Which is the ideal one to use without having to plug things up. Thats if you want to keep egr all together. Ive deleted mine with a block off plate, no issues so far.
Old 04-29-2013, 09:16 PM   #29
93slowstang's Avatar
I have checked mine with a mic and the explorer intakes are only 67-68 mm openings. Spot on otherwise.
Old 04-29-2013, 09:34 PM   #30
Dion11197's Avatar
I would also take into consideration what the final goals are. For me I plan on going forced induction and don't want to spent the money twice.
Old 05-05-2013, 07:16 PM   #31
_MrFoxbody_'s Avatar
I'm looking at a gt40 intake online.. what's the deal with some having an egr port and some not having it? which one do I get?
_MrFoxbody_ is offline   Reply With Quote
Old 05-05-2013, 07:32 PM   #32
havhammer's Avatar
What do you have(car) and do you plan on keping the egr fuctional?
Old 05-05-2013, 07:35 PM   #33
1991 gt.. and yeah I want to keep it functional.. I just don't know which one to get
Old 05-05-2013, 09:38 PM   #34
Dion11197's Avatar
Get the one that has the external EGR.
---------- Post added at 08:38 PM ---------- Previous post was at 08:37 PM ----------
It'll look the same as ADogg's.
Old 05-05-2013, 10:21 PM   #35
Uh, a 91 has internal EGR, get the internal EGR one if you want to keep the EGR functional...
08:28 PM
