Budget - Mustang Evolution
Old 04-26-2013, 08:31 AM   #1
Cblackstang's Avatar
Budget
I have 200$ now to spend so undecided on 75mm TB or 3:73 gears..what do you guys think? And also would it benefit any if I bumped my timing?
Cblackstang is offline   Reply With Quote
Old 04-26-2013, 08:40 AM   #2
1lowGT's Avatar
Gears. But that's gonna cost more than $200 for parts and labor.
Old 04-26-2013, 08:47 AM   #3
I do all my own work
Old 04-26-2013, 09:01 AM   #4
Venomouz831's Avatar
If you can install gears then go ahead and get those
)02 Gt, Founder of WE2G
Old 04-26-2013, 11:33 AM   #5
WhiteCobra94's Avatar
Gears
Old 04-26-2013, 11:40 AM   #6
Gears gears gears gears gears gears gears gears.
And then another $75 or whatever it costs for the speedcal...
Also from your pic I'm assuming you have a 94/95, why in hell would you get a 75mm TB when the intlet opening of the stock intake is only 70mm?
edit: Yeah you'll pick up a little power bumping your timing to 14 degrees but you will need to run premium gas.
Old 04-26-2013, 11:45 AM   #7
I planned on getting another intake in a couple months
Old 04-26-2013, 11:54 AM   #8
I have a 75mm TB but when I had my intake ported and polished I had the inlet ported out to 75mm to match the throttle body !!
Old 04-26-2013, 01:22 PM   #9
maldog's Avatar
Region: Nevada
Gears.....Gears...
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 04-27-2013, 11:27 AM   #10
Sgt_Syke's Avatar
Def gears, no power gain, but it will feel like it.
Sgt_Syke is offline   Reply With Quote
Old 04-29-2013, 05:23 AM   #11
Bane-'s Avatar
whats done to the motor to see if the 75mm is even needed?
Ive got a 70mm on my 89 and a 65mm would still prally do just fine, was just on it when I bought it. Bigger isnt always better.
Old 04-30-2013, 12:23 PM   #12
Gears
Naut is offline   Reply With Quote
« Gas milage | Shop »
05:07 PM
