Need some guidance - Mustang Evolution
Old 04-27-2013, 02:08 PM   #1
89notchbeast's Avatar
Need some guidance
Ok...I've had this 89 for a couple of months now...it's always had idle problems from the get go...it's got a bit of mods...373 gears , gt40 heads and intake , msd ignition , b&m short throw , cam ....always had to give it a little gas to keep it from dying the first start of the day...after that it would start right up...surging at idle has always been an issue and bucking while driving....replaced tps , mass air , timing chain , and got it timed.....now it starts right up but still fluctuates 700-3000 rpms at first then 700-1500 after it warms up also no vacuum leaks...only codes the car had were tps and mass air ...any suggestions?
89notchbeast is offline   Reply With Quote
Old 04-27-2013, 02:30 PM   #2
Dion11197's Avatar
Have you checked the idle air control valve?
Dion11197 is offline   Reply With Quote
Old 04-27-2013, 04:06 PM   #3
93slowstang's Avatar
You may need to set your idle and tps. There is a sticky in the useful info for it.
Old 04-28-2013, 09:22 AM   #4
No already done that 99v at like 900 rpm ...
---------- Post added at 10:22 AM ---------- Previous post was at 10:21 AM ----------
Yes the iac is brand new and working
Old 04-28-2013, 09:48 AM   #5
I'm gonna change the fuel filter and try some sea foam .....this week see if it helps any
Old 04-28-2013, 12:07 PM   #6
rick9550's Avatar
You have an aftermarket throttle body?
I know the computers were different but...my 95 GT had surging issues after heads, intake and cam swap. Ran like a beast at WOT though so my area of contention (see what I did there? ) may not be the same. anyways I thought I would share.
Had my friend the Ford mechanic look at it. He had just done basically the same swap on his 94 GT but didn't have the surging issues.
He just backed out the, what looked like, the idle air screw on my BBK throttle body and it cleared it right up. I know on the stock throttle bodies there is no screw in this spot. That's why I ask if you have an aftermarket TB.
Just a thought before running sea foam through the car.
2011 GT Premium Black on Black, Eibach Sportline, Eibach Camber Bolts, BMRAdjustable Pan-hard bar, 19 x 9 Replica Boss 302 Laguna Seca, 275/35-19, GT/CSFront Fascia, C&L CAI, SCT SF3 w/ Bama Tune, Bassani Axle backs.
rick9550 is offline   Reply With Quote
Old 04-28-2013, 03:49 PM   #7
I think I'm gonna try adjusting the idle again ..thanks...I just brought it to a shop and they couldn't fix it ...lol...that's who changed the mass air...they said give the computer a week to adjust...hahaha...bowl ****!
Old 04-28-2013, 04:20 PM   #8
Ok...adjusted the idle ....running better but still not right ...best I could get it was 900-1000 rpms at 1.12 volts....98-99 volts runs bad
Old 04-28-2013, 09:50 PM   #9
Krazy Horse's Avatar
Sounds like you need a tune. SCT Bama chip with a list of your mods to them when you order it. Best bang for your buck at this point if you want it to behave while driving on the street
Krazy Horse is offline   Reply With Quote
Old 04-29-2013, 02:45 PM   #10
The only thing I haven't changed is the EGR valve .....could it be that?
Old 04-29-2013, 04:12 PM   #11
rick9550's Avatar
I wouldn't think so. You could just disconnect it or cap it off and see if that changes anything. Did you replace the PCV valve too?
Old 04-29-2013, 04:58 PM   #12
I will look into Pcv tonight ...how do I test it?
Old 04-29-2013, 07:18 PM   #13
You said you have a cam? What you describe is classic E cam and that is the cam that most ppl put in a stock headed motor who don't know any better. Honestly, if you put a cam into a stock headed 5.0 you're either going to lose power or just move the power band up a little. A custom dyno tune will help if you've got a cam but at $600 just to get the idle tuned... I'd throw a stock cam back in there, get my stock driveability back and call it a day unless you are going to do the heads/intake in the near future.
Old 04-29-2013, 07:21 PM   #14
Thanks .... Dyno tune it is....I do plan on twisted wedge and trick flow
Old 04-30-2013, 12:49 AM   #15
LightningR's Avatar
Region: Idaho
I know this sounds funny but you may just rotate your mass air meter in slight increments in either direction.
LightningR is offline   Reply With Quote
Old 04-30-2013, 06:01 AM   #16
rick9550's Avatar
Yep. Good call. Forgot about that one.
Old 04-30-2013, 01:51 PM   #17
Thanks lightning I'll give it a try....funny thing is at one point I had it running perfect at 1100 rpms and when I changed mass air and tps I couldn't get it back
Old 04-30-2013, 08:52 PM   #18
Turn the whole mass airflow unit body and all or do I have to take it apart?
Old 05-01-2013, 05:19 AM   #19
Dion11197's Avatar
If I remember correctly it's the whole unit. Just turn it in small increments to see if it corrects itself.
Old 05-01-2013, 10:03 AM   #20
Thanks ...I will try it and let you guys know
Old 05-01-2013, 10:50 AM   #21
DustyStang306's Avatar
You don't need a dyno tune with that set up my stock a9l runs my 306 with edelbrock heads an a x cam just fine an the first start up I used the stock 19# injectors before an idled fine The a9l computer take very well to mods an doesn't need a tune until you go with boost until then you should be fine with the stock computer doing its job fine. do you have the stock injector or do you have 24# injectors?
DustyStang306 is offline   Reply With Quote
Old 05-01-2013, 04:35 PM   #22
I had a HCI car with a A9L and it benefitted greatly from a tune.
Old 05-01-2013, 06:57 PM   #23
Will be back later tonight with more info..need to see what motor I have in it....I might be setting everything for regular 302 when it might be a cobra/explorer because the deck lid is about 11/2 2 inches higher than normal....couldn't fit a stock hood on it
Old 05-01-2013, 08:23 PM   #24
Turning the mass air really works....don't know if its good enough yet but seems to be holding a steady idle and jerking is very minimum... I'll let you guys know tomorrow ....thanks
01:25 AM
