Loud chirping comes and goes 89 GT - Mustang Evolution
Old 04-29-2013, 05:47 PM   #1
Patches89's Avatar
I am completely stumped. I get a very loud chirping sound after driving for 5-10 minutes. When the chirping starts I press on the brakes and the noise stays the same and slows down with the car. When I then accelerate it will stay the same and increase. I thought for sure it would be a seized caliper and the brake pads were just rubbing causing heat and therefore the chirping. I was wrong. I replaced the calipers, rotors and pads and the sound is still there and the same! It sounds like it is under directly under my feet and braking, accelerating or coasting does not make it go away. It just chirps to the speed of the wheel revolution. Again this sound only starts after 5 minutes of driving and only is audible driving about 45 mph and under. If I go on the highway it seems to too fast and I hear no chirping sound. Can anyone help before I spend my saving on throwing parts at it.
Patches89 is offline   Reply With Quote
Old 04-29-2013, 07:14 PM   #2
Does it go away when you push the clutch in? If its not the clutch TOB then it sounds like a wheel bearing.
Old 04-29-2013, 08:00 PM   #3
Patches89's Avatar
Unfortunately it is an automatic. I thought bad wheel bearings make a grinding sound. Do they also make high pitch chirping noises? Also when I replaced the rotors I repacked all the bearings and the sound is still exactly the same as before . Would the bearing still squeal if I repacked with grease?
Old 04-29-2013, 08:11 PM   #4
93slowstang's Avatar
It could be the type of brake pads you have. Semi metallic pads will chirp like that.
Old 04-29-2013, 08:35 PM   #5
Patches89's Avatar
The sound seems to be coming from under the car. Does not seem to be coming from the wheels. Could it be the drive shaft? When I take my foot off the gas the sound continues. Sounds like it is directly in the middle of the car.
Old 04-29-2013, 08:42 PM   #6
Dion11197's Avatar
Could be. I'd check your universal joints and input shaft. Did you change drive shafts recently?
Dion11197 is offline   Reply With Quote
Old 04-29-2013, 08:43 PM   #7
Patches89's Avatar
No, did not touch anything on the drive shaft. Would that make a high pitch squeal noise or more of a clunking?
Old 04-29-2013, 08:47 PM   #8
Dion11197's Avatar
I've actually heard both, but usually a clunk more than a chirp.
---------- Post added at 07:46 PM ---------- Previous post was at 07:45 PM ----------
Just a thought, did you check your dust shields?
---------- Post added at 07:47 PM ---------- Previous post was at 07:46 PM ----------
Does it happen more on rough roads then smooth?
Old 04-29-2013, 08:54 PM   #9
Patches89's Avatar
I checked them when I changed out the rotors. Everything looked fine, but maybe I should take another look.
The sound happens on smooth roads.
Old 04-30-2013, 05:17 AM   #10
Dion11197's Avatar
Since it seems consistent with wheel speed I would take the side it sounds like its coming from off and inspect the inside of the wheel real good and spin the rotor by hand. Also spin with the wheel on to see if you get anything and go from there. I would check both just to rule things out.
Old 04-30-2013, 10:16 AM   #11
driveshaft turns as well, look under there for wear marks or shinny spots for something hitting something else~
Old 04-30-2013, 02:53 PM   #12
foxbox's Avatar
Speedo cable!
foxbox is offline   Reply With Quote
Old 04-30-2013, 04:23 PM   #13
Dion11197's Avatar
Forgot about that one! My buddies did that, got it greased and he was go to go.
Old 04-30-2013, 06:25 PM   #14
Patches89's Avatar
Thanks for the help! I am taking it to a local shop on Thursday to see what the issue is. I do not have much experience at all working on cars and just learn from YouTube videos. I will let you know what I find out.
Old 05-01-2013, 03:54 PM   #15
fordtough1991's Avatar
I know you say it's coming from under the car but if your runing the a/c while driving the clutch on the compressor might be out and making that noise
fordtough1991 is offline   Reply With Quote
Old 05-01-2013, 06:40 PM   #16
Bane-'s Avatar
dpending on how long I have the ebrake set on my car, after an extended period of time of it not moving the rear drums squeek a little.
needless to say, dont set ebrake = not squeeky drums was an easy fix lol
Old 05-06-2013, 07:15 PM   #17
Patches89's Avatar
Well, got back from the shop and they could not reproduce the sound. After driving for about 30 minutes, average speed about 30 mph, the noise started again. I opened the door and hung my head to hear the noise better. Sounds like it is the rear wheels. The sound is high pitch. Took the drum off the rear and did not see anything that suspicious.
I may just change the rear brakes to eliminate a possible cause.
Thank you everyone for your help.
01:30 PM
