Tire size for 93 - Mustang Evolution
Old 04-30-2013, 04:29 PM   #1
Scottnos1's Avatar
Tire size for 93
Can I fit a 255/40/18's on the front ? And I just put in adjustable lower control arms on the rear can I take out the quad shocks so I can put 275/40/18's
Scottnos1 is offline   Reply With Quote
Old 04-30-2013, 05:35 PM   #2
aegischief's Avatar
Rear should fit with the quads removed. Fronts will fit but are probably gonna rub when turned all the way over.
aegischief is offline   Reply With Quote
Old 04-30-2013, 06:59 PM   #3
Bane-'s Avatar
what size wheel?
front:
18x8 might work
18x9 most likely rub when turning
rear:
should be fine with no probs after quads are removed
Old 04-30-2013, 07:09 PM   #4
2300turboford's Avatar
I run 17x9 in front and 17x10 245 in front and 275 in back front barley runs at full lock
Old 04-30-2013, 07:32 PM   #5
Scottnos1's Avatar
Originally Posted by Bane- View Post
what size wheel?
front:
18x8 might work
rear:
I have 18x9 rims all around.
Will I have to work the fender?
Old 04-30-2013, 07:46 PM   #6
Scottnos1's Avatar
What profile do u have
Old 05-01-2013, 06:35 PM   #7
Bane-'s Avatar
245 on a 9" rim is to small... I mean it fits, but its going to look funny.
Id say yes you will prally have to work the inside of the fenders and all depending on if its lowered or not. the lower you are, the most likely it wont fit.
Old 05-02-2013, 03:50 AM   #8
93slowstang's Avatar
245s fit 9" wheels like a glove.... Not stretched and not bulging over the edges.
Old 05-02-2013, 03:54 AM   #9
If you're lowered anything over a 245 in the front will rub the fender more than likely. I ran 235s in the front lowered 2.25" with 0 rubbing issues and running 245s now and the only time they rub is when I hit a decent size bump.
Old 05-02-2013, 08:03 AM   #10
Bane-'s Avatar
the 245 I had and have seen fit ideally on a 8" wheel. I wouldnt run anything less than a 255-265 on a 9" wheel
Old 05-02-2013, 01:29 PM   #11
These fit perfect on mine, though I will be putting 275 on the back when I get a chance.
10:48 AM
