Fuel pressure problem - Mustang Evolution
Old 05-01-2013, 08:10 AM   #1
Lewisunderwood's Avatar
I got a 88 gt. non roller 302 from ford truck holley 6oo street avenger starving of fuel how much fuel pressure does it need to run it has a universial pump u buy from autozone its doing about 3.5-4 psi at idle were should it b stock motor when i go up the rd it will have power thru first starve in second gear any help appreciated thats
Lewisunderwood is offline   Reply With Quote
Old 05-01-2013, 09:26 AM   #2
Foxtrot's Avatar
I would first check the fuel filter if you are running that low it sounds like you have a block some where I would start with that. I also believe stock fuel pressure is around 35-40 psi. I'm not 100% sure but someone else will probably chime in with more info.
Foxtrot is offline   Reply With Quote
Old 05-01-2013, 02:14 PM   #3
Greatly appreciate info
Old 05-01-2013, 07:39 PM   #4
havhammer's Avatar
Is it carburetored?
havhammer is offline   Reply With Quote
Old 05-02-2013, 07:15 AM   #5
Bane-'s Avatar
DO NOT RUN 35-40psi TO YOUR CARB! Thats the efi fuel pressure.
If 3.5-4 isnt enough I would just bump it up a little at a time to see if that helps, also check your timing it could be out of whack
Old 05-02-2013, 08:18 PM   #6
Foxtrot's Avatar
Ye sorry about that I wasn't thinking. You are right do not run that!
02:11 PM
