5.0 HO vs. 5.0 NON HO motor - Mustang Evolution
Old 05-05-2013, 06:40 PM   #1
Pgfdv6's Avatar
hey all so im in the process of building my car up to do a little bit (well actually quiet a lot of) AutoX/road racing and I am in the process of getting ready to set the motor now the motor that I will be putting in to just get the car moving is that out of 1988 Lincoln Town Car which is the NON HO 5.0l motor now many questions follow such as
are there different pistons in these two motors
what are basic differences
and are there any pros an cons to one over another
the HO motor is 9.1:1 i believe while the NON HO is 8.9:1
or if anyone has any other info about these motors that they think could be useful to me please go ahead and post up
thanks in advance
Shelby.
Pgfdv6 is offline   Reply With Quote
Old 05-05-2013, 08:05 PM   #2
ProjectTurboV6's Avatar
Originally Posted by Pgfdv6 View Post
*I know this might be the wrong section but figure i could use some of you guys knowledge also*
thanks in advance
Shelby.
I don't know a lot about these motors, but I can share some knowledge. If you didnt already know, HO means High Output. The higher compression engine 9 times out of 10 is the better to have. Your best bet for an autox car would have the matching year engine dropped into her, that way you know it will bolt right in. Second, the modular 4.6 4v engine would be a much better platform. It's a dohc engine with an an aluminum block so its lighter/better for corner cutting.
ProjectTurboV6 is offline   Reply With Quote
Old 05-05-2013, 10:00 PM   #3
91notchback's Avatar
Different firing orders...
91notchback is offline   Reply With Quote
Old 05-05-2013, 10:09 PM   #4
andregayola's Avatar
how can the two make more horsepower
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 05-05-2013, 10:35 PM   #5
93slowstang's Avatar
Well the pushrod 5.0 is lighter than the 4.6 by around 50lbs.
Old 05-05-2013, 10:36 PM   #6
The H.O. Is a roller motor with a different firing order than the non H.O. Also the heads lift and intake play a part in the Hp difference as well.
Old 05-05-2013, 11:10 PM   #7
^^*+5.0 what I was gettin at without so many words...lol!
---------- Post added at 12:10 AM ---------- Previous post was at 12:06 AM ----------
From what i know: the roller 5.0 has the 5.8 firing order. Correct me of I'm wrong,..
Old 05-06-2013, 12:05 AM   #8
3stangs's Avatar
The HO motors just have the 351 firing order. If its from a 88 Lincoln it should be a roller block. As far as getting a motor from the same year vehicle to make sure it'll drop right in.....ANY 302 will bolt right it. The year does not matter.
3stangs is offline   Reply With Quote
Old 05-06-2013, 07:20 AM   #9
deadsp0t's Avatar
This
That's unimpressive
Old 05-07-2013, 02:21 PM   #10
HO = 5.8 firing order. Compression on the engine has more to do with the year of production as the same pistons were not used in all stock 302's.
ProjectTurbov6. The 4.6 4v motor even though it is aluminum is heavyier than the iron block 5.0 motor even with iron heads. The 4v is not even close to being lighter than the 5.0 OHV engine as even the aluminum 2v motors are heavier.
Furthermore the Windsor OHV engines are a better corner caver mustang option than the Modular engine. Take a look at american iron for instance, the most competitive racers are running Windsors.
DieselStang is offline   Reply With Quote
Old 05-07-2013, 03:22 PM   #11
Pgfdv6's Avatar
Well I plan on running gt40 heads so wouldn't that mean I could use a stock 5.0 cam which would also be the stock firing order or no?
Old 05-07-2013, 06:27 PM   #12
What firing order your engine will have depends on which stock 5.0 cam you speak of. Either cam you use both will work fine with GT40 heads. Note that the HO cam with the 5.8 firing order is a little better at making power.
Old 05-08-2013, 02:06 AM   #13
3stangs's Avatar
The cam does not dictate the firing order. With any cam you use other than the explorer cam will require you to upgrade the springs. Gt40 or gt40p heads have springs that are inadequate for performance cams
Old 05-08-2013, 03:56 AM   #14
Yes a cam does dictate firing order. If you put an HO cam in a non HO block you must use the HO firing order for it to run.
Old 05-08-2013, 04:02 AM   #15
3stangs's Avatar
Wrong^^^ the cam is not what makes it HO.
Old 05-08-2013, 04:10 AM   #16
deadsp0t's Avatar
Lmmfao... Wow.. ^you should probably do a little research and get educated on how an internal combustion engine works.
That's unimpressive
Old 05-08-2013, 04:29 AM   #17
2300turboford's Avatar
+1
Old 05-08-2013, 04:37 AM   #18
+2
Old 05-08-2013, 06:24 AM   #19
3stangs's Avatar
Already took that class. The crankshaft dictates firing order cause why.......that positions the pistons genius
Old 05-08-2013, 08:03 AM   #20
The cam opens the valves, change the cam to a different firing order and they open on a different stroke meaning you have to change the firing order. You can pretty much make an engine have any firing order you choose ( obviously with certain limitations), look up custom firing order cams. Apparently you need to go to a real class....
Old 05-08-2013, 10:53 AM   #21
Pgfdv6's Avatar
So my GT40 heads will work with a stock cam or i have an option for a performance cam if I can go performance cam any one have suggestions ill be doin some research on them later tonight after work
Old 05-08-2013, 11:25 AM   #22
Yes they'll work fine with the stock cam. I would look at the b303, e303, trickflow stage 1, or steeda #18 if your looking for decent mild lift cams. Prepare to put better valve springs on those heads if you do put an aftermarket can in.
Old 05-08-2013, 07:19 PM   #23
3stangs: The cam and change in firing order is indeed what makes the 5.0 "High Output." Anyone whose been around a 5.0 HO motor for 30 seconds knows that.
Old 05-08-2013, 07:23 PM   #24
DustyStang306's Avatar
+1
DustyStang306 is offline   Reply With Quote
10:09 PM
