91 GT troubles - Mustang Evolution
Old 05-07-2013, 02:57 PM   #1
95GTvert's Avatar
91 GT troubles
Hey guys, my cousin called me and said his car is not going into 1st, 2nd, 3rd, or 4th "sometimes" but will go into 5th, and once he gets going at higher speeds in 5th, he is then able to downshift into all 4 other gears and its normal. But like I said, it only does it occasionally, not all the time. Any ideas? Clutch need adjusted maybe? It's a 5.0 car, lots of bolt ons.
95GTvert is offline   Reply With Quote
Old 05-07-2013, 03:28 PM   #2
MidnightBlueGT's Avatar
Has he checked the syncros? Thats a common problem in srt's 3rd gear and its the syncro.
Old 05-07-2013, 04:20 PM   #3
95GTvert's Avatar
Would that effect all 4 gears? It happens in 4th the same as 1,2,and 3. It doesn't grind, just won't go into gear.
Old 05-07-2013, 04:21 PM   #4
BatmanUriah's Avatar
It sounds like a problem with the pressure plate.
BatmanUriah is offline   Reply With Quote
Old 05-07-2013, 04:51 PM   #5
DustyStang306's Avatar
+1 maybe it's got really old fluid in it or maybe low or maybe the rear main seal is leaking slow my rear main seal was leaking a bit on my last motor an at high rpms I couldn't shift quickly between 1st an 2nd or it would grind. if he really try to put it in will it grind? I have never hear of one not being abel to go in to gear at all just really hard an grinds
DustyStang306 is offline   Reply With Quote
Old 05-07-2013, 05:00 PM   #6
95GTvert's Avatar
Pressure plate sounds like could be the issue, I will let him know n see if he can check it out. He said it wasn't grinding which sounded weird to me also, said he was tryin hard to get it into gear, but wasn't. But 5th goes right in just like normal. He had to take off in 5th, sure his clutch is gonna be shot if he does that much more.
Old 05-09-2013, 10:22 PM   #7
93slowstang's Avatar
Needs to adjust the clutch. Either the cable has stretched some or the clutch has worn enough to need adjusting.
Old 05-10-2013, 04:55 AM   #8
95GTvert's Avatar
Ok thanks, I need to call him and see how its going. The clutch is very stiff in that car, and I think its a new clutch. Figured that's why it was stiff.
08:01 AM
