Idle problems - Mustang Evolution
Old 05-09-2013, 03:49 PM   #1
Region: West Virgina
Idle problems
Hey guys I have a 88 gt 5.0 auto with shift kit the idle goes up and down till it shuts off but when u start to drive then it idles at 2000 rpms till the car is shut off it has a new ICA valve and didn't help and advice
Mustangnutz is offline   Reply With Quote
Old 05-09-2013, 04:55 PM   #2
tonyd01gt's Avatar
Check all the vacuum lines on the lower intake and going to the TB. check the TB ,ICA , upper intake gasket.
tonyd01gt is offline   Reply With Quote
Old 05-09-2013, 05:07 PM   #3
Ok I couldn't find no leaks but ill look again thanks for the input
Old 05-09-2013, 05:20 PM   #4
tonyd01gt's Avatar
Your power brake booster should also have a vacuum line into the intake manifold. if my memory is correct. check every vacuum line .also check the lower intake manifold for vacuum leaks. it this car still a speed density car without a MAF ?
Old 05-09-2013, 05:28 PM   #5
Yeah its not MAF and ill keep checking
Old 05-09-2013, 05:36 PM   #6
tonyd01gt's Avatar
Check the Map sensor. it will cause that kind of problem. how much has the car been modified. your system ECU will only allow a small window on increasing the HP on it.
Old 05-09-2013, 05:39 PM   #7
Just cold air intake and flow master where's the map senser this is my first fox thanks for all the advise
Old 05-09-2013, 05:45 PM   #8
tonyd01gt's Avatar
it should be bolted to the firewall behind engine.Vacuum line and electrical connection on it.
Old 05-09-2013, 05:56 PM   #9
Ok I'll check
Old 05-11-2013, 06:55 AM   #10
Ok checked map sensor tps sensor can't find any vacuum. Leaks and still having the same problem
Old 05-11-2013, 11:04 AM   #11
tonyd01gt's Avatar
disconnect the electrical connection from the MAP sensor.Should be a change in idle. if it is working correctly. if no change in idle that is your problem.
Old 05-11-2013, 11:42 AM   #12
Put a new map sensor still didn't fix the problem
Old 05-11-2013, 11:50 AM   #13
tonyd01gt's Avatar
this is a fox body vacuum system .if you have checked all these vacuum lines.and founded no cracks or leaks. and test the Map sensors. Maybe someone else will/can give more info.
Old 05-11-2013, 11:53 AM   #14
I keep checking for vacuum leaks just to make sure I haven't missed anything thanks for all your help and info
Old 05-12-2013, 06:14 PM   #15
Ok so finally pulled a code firm my mustang today it showed the was a problem with the thermatic air diviter has any one heard of this before
Old 05-13-2013, 03:17 PM   #16
5.slow's Avatar
Region: Delaware
It's the valve that splits the air coming from the smog pump to the back of the heads or catalytic converters. It should have a vacuum line into the top of it. Check to make sure you don't have a leak there.
5.slow is offline   Reply With Quote
Old 05-13-2013, 03:19 PM   #17
Yeah it's has a big crack in it I'm going to have to buy a new one
Old 05-13-2013, 08:12 PM   #18
LightningR's Avatar
Region: Idaho
Nope sorry, doesn't sound expensive tho!
LightningR is offline   Reply With Quote
Old 05-13-2013, 08:22 PM   #19
5.slow's Avatar
Region: Delaware
Most people delete the smog pump system anyway. I can still pass the sniffer without mine but you may be able to get one free from someone who is deleting their smog pump.
Old 05-14-2013, 03:27 AM   #20
Pick one up last night brand new 49 bucks
02:48 AM
