Help❗❗ 91 starting problems - Mustang Evolution
Old 05-12-2013, 10:59 AM   #1
Ronn501's Avatar
Region: Arkansas
Everything works I get power to my dash but I just won't start doesn't turn over or anything... Plz help
Ronn501 is offline   Reply With Quote
Old 05-12-2013, 11:45 AM   #2
93slowstang's Avatar
Have you checked your solenoid?
Old 05-12-2013, 12:12 PM   #3
Tkcobrasvt's Avatar
Check your ground wires. Timing cover ground. Frame ground. Both battery terminals might be loose . Starter ground might be lose. Or last and finial your starter is shot and locked up.
Tkcobrasvt is offline   Reply With Quote
Old 05-12-2013, 12:38 PM   #4
Ronn501's Avatar
Region: Arkansas
I replaced the starter solenoid and I cranked up but wen I cut it off I DDnt Kum back on but everything's works far as lights top windows all power Accessories
Old 05-12-2013, 12:43 PM   #5
It's not me, it's you.
primer2tone's Avatar
If it cranked once before and it's not now, it's gotta be a wire problem. Give all your connections related to the starter a jiggle.
Old 05-12-2013, 02:20 PM   #6
Ronn501's Avatar
Region: Arkansas
Ok I will do it... And my battery drains also so wjats does that tell u
Old 05-12-2013, 02:22 PM   #7
Ubnbit's Avatar
Means something is grounded out somewhere. Either that or the battery is done. What all have u checked, changed or done?
Old 05-12-2013, 02:52 PM   #8
Ronn501's Avatar
Region: Arkansas
Ok I'll try it but my battery drains also
Old 05-12-2013, 03:04 PM   #9
Ronn501's Avatar
Region: Arkansas
Well for sum reason sum idiot spliced 1 of the yellow ignition wire and it's runnin to the fuse box for some odd reason
Old 05-12-2013, 10:03 PM   #10
What fuse is it connected to?
Old 05-13-2013, 09:18 AM   #11
Ronn501's Avatar
Region: Arkansas
It's connected to curtsy lamps, radio, lumminated entry
12:32 PM
