problem starting - Mustang Evolution
Old 05-14-2013, 08:27 PM   #1
problem starting
proud new owner of 1st pony. 89 gt. car wont start. turn key and got power. then turn it again i get nothing. dont know much bout fixiin cars or parts and what they do but sure i will begin to. car has a safety in the trunk and i have reset it but nothing. and it does seem to be the same symptom that has normally worked when reset.
kayoss146 is offline   Reply With Quote
Old 05-14-2013, 09:52 PM   #2
First easy thing is battery? Any autozone, orieley's, etc can test that. The next thing I would think of to check is the starter solenoid. You can jump the two posts with a screwdriver when starting and see what you get.
Adam302gt is offline   Reply With Quote
Old 05-14-2013, 10:15 PM   #3
Sgt_Syke's Avatar
The main things to check are connections, battery, starter solenoid, and ignition switch. Check wiring of button in trunk, sounds like maybe someone tried installing a kill switch? Shrug? Start with easiest thing first. All connections to battery terminals, grounds. Check battery, then check solenoid by bridging the two posts with a metal object (screwdriver) as you crank engine, then check ignition switch inside column. If none of that finds the problem then it has to be that button in the trunk. I don't think that would cause your problem. My guess would be ignition switch (common problem) or solenoid. Good luck.
Sgt_Syke is offline   Reply With Quote
Old 05-15-2013, 01:43 AM   #4
problem starting
yes as a matter of fact the dude i got car from did put a kill switch on for me when i got it from him but would it cause a problem after several starts? and like i said i dont know about fixing things really yet, so the solenoid?
Old 05-15-2013, 12:58 PM   #5
Sgt_Syke's Avatar
Solenoid is on the fender probably driver side, google how the starting system works, that will help a lot. Time to go back to school.
Old 05-15-2013, 08:55 PM   #6
ok so when i check the solenoid what flaws or defects am i looking for? how will i know if it needs to be replaced
Old 05-15-2013, 09:51 PM   #7
Well in short, when you try to start it and it doesn't start and then you jump the solenoid and it does start then you know it is probably faulty. I think there are a few YouTube videos about it if you want to check those out.
07:32 AM
