Sunroof Mods - Mustang Evolution
Old 05-20-2013, 07:57 PM   #1
91MustangNSB's Avatar
Sunroof Mods
Hey everyone so I was just wondering if there are any mods for making the sunroof either pop up higher or make it removable to I could take it off of hot days thanks
91MustangNSB is offline   Reply With Quote
Old 05-21-2013, 04:02 PM   #2
foxbox's Avatar
If you squeeze the the two pieces that prop the window up it will pop right out. Its already made to come out.
foxbox is offline   Reply With Quote
Old 05-21-2013, 05:28 PM   #3
So are u saying that its made to be a removable sunroof and where exactly are the places to that release it ? Thanks
Old 05-21-2013, 06:57 PM   #4
foxbox's Avatar
The latch that you use to lift the sunroof has two chrome metal pieces. They are spring loaded so you may have to squeeze them tight. First, raise the sunroof like you have been doing. Next, look at what is propping the sunroof up; there should be two pieces of that lever that are holding it up. Finally, squeeze the two piece together and the sunroof should slide up and off. You will have to step outside the car to pull it off without dropping it on your roof. If all else fails, I am sure there is a youtube video of someone taking it off. I swear it not complicated at all man, if ya cant figure it out just pm me and ill talk ya through it. Btw yes it is made to be removed
Old 05-21-2013, 09:04 PM   #5
93slowstang's Avatar
This^. If it hasn't been removed in a while it may be hard to compress the two pieces.
Old 05-21-2013, 09:37 PM   #6
Thanks for all the help ill try to remove it tomorrow and let you guys know how it goes
Old 05-23-2013, 09:39 AM   #7
Thanks for the help and foxbox u were right about the dropping on the roof thing, it's a lot easier when there is some help
Old 05-23-2013, 12:59 PM   #8
10:01 PM
