cam choice - Mustang Evolution
Old 05-23-2013, 08:34 PM   #1
busaboy's Avatar
cam choice
What is a good mild can I can put in with out changing heads, or anything else right away
busaboy is offline   Reply With Quote
Old 05-23-2013, 08:58 PM   #2
DustyStang306's Avatar
The b303 or e303 are good to work with stock heads still should check piston to valve clearance when doing any cam
DustyStang306 is offline   Reply With Quote
Old 05-23-2013, 10:18 PM   #3
93slowstang's Avatar
Either one of those choices and he'll be good with the PTV on stock heads.
Old 05-24-2013, 05:53 AM   #4
Still should always see how much room you still got but yes he will be fine with ptv using ether one of those cams
Old 05-24-2013, 10:34 AM   #5
busaboy's Avatar
Is either one better than the other in any way? I like when it has that glug sound if you know what I mean so closer the better
Old 05-24-2013, 10:58 AM   #6
Heres a link with all the specs on them I had a b303 cam in my last motor an it work great but I think the e303 is better an passes smog test if you still need to haha but you could go with the b303 an get 1.7 rockers to get a little more lift an the ptv should still be fine with 1.7 an a b303 I'd still work check if your doing it your self. Do you have stock heads? I would do the gt40 or gt40p swap at the same time if you still got the e7s just to get the most out of the cam
---------- Post added at 11:58 AM ---------- Previous post was at 11:56 AM ----------
http://www.jegs.com/fordracing/ford_50l_cam_specs.html
Old 05-24-2013, 04:01 PM   #7
WhiteCobra94's Avatar
Your not gonna gain much if any with the B or E cam with stock heads , your better off changing your rocker arms to 1.7 with a stock cam until you upgrade your heads then swap the Cam and do it all at once!!
Old 05-24-2013, 10:43 PM   #8
If you have stock heads leave the stock cam, you will not gain any power with a new cam and any stock heads minus the GT40s which you do not have. All a new cam will do is move the power band and you actually might lose power.
Old 05-25-2013, 05:11 PM   #9
Billymich's Avatar
The sound you are looking for is obtained by overlapping intake and exhaust profiles. That's not gonna work well with stock heads. I would move to 1.7 RRs, it will be easier to do anyways.
Old 05-25-2013, 09:05 PM   #10
busaboy's Avatar
I'm looking to get some different heads just not sure what yet like to get gt40 heads but still not sure if they'll work with the flat top pistons I have and save for better ones I just found out a guy I know is still running his machine shop and wondering if there's anything he can do and with what he ported and polished and bored my quad but again I don't really know what to get and or what I could ask him to do to make the best out of what I got if there is anything...lol...E6BE heads 86 block with flat top pistons big asss paper weight!!! Or boat anchor hahaha
Old 05-25-2013, 10:20 PM   #11
Billymich's Avatar
Just save up and get some good lightweight alum heads. http://www.speedwaymotors.com/Flo-Te...ads,46332.html
Cheapest fully assembled alum heads on the market, with enough meat for a good port down the road, these heads will save 50lbs and with some supporting mods will dyno at 300rwhp
These are *bargains* but when I say CHEAPEST I mean it in both ways...
Old 06-02-2013, 09:26 PM   #12
silverstangboy's Avatar
i'd look at some canfields as well, reputable company. the heads will not require clean up work to get right.
as posted above by scotty i would leave the stock cam, it really is a good cam for this engine and I have seen plenty of guys running 11's with it, not sure why everyone is so quick to ditch the thing, just run some 1.7's on the exhaust side of the cam.
93 mustang notch
~450hp 331 stroker - Sold
Old 06-11-2013, 09:31 AM   #13
Ronn501's Avatar
Region: Arkansas
Hey can 1 of u guys call me I have a couple of questions that need to b answerd thoroughly
5013104662
Ronn501 is offline   Reply With Quote
09:09 PM
