Just bought a 92 hatch 5.0 - Mustang Evolution
Old 05-25-2013, 08:43 PM   #1
Dykzeulb's Avatar
Hello all, new to the mustang, but a loyal Ford owner. Just bought this car this weekend. I have wanted one if these since I was a kid, I'm 24 now. The body is pretty rough so I am searching for a rolling chassis now, but it has the 5.0 with what I would call lots of mods. It has the trick flow kit, blue injectors, hi flow fuel pump, headers, 4 core radiator, and more. I also got like 15 boxes if parts like E-fans and other stuff as well as the rear window louvers. Car sound great, needs a new plug wire as it rubbed the header on the way home and developed a bad spot in the shielding. The main issue now is the ignition- currently has a "rattler" alarm installed and I cannot get it to start unless it is jumped (solenoid) common sense told me to replace the solenoid, so I did..still have to jump it. I am thinking the alarm is not allowing it to start, I turn the key and everything kicks on, then roll the key to start and nothing, which tells me it's electrical between the switch and solenoid. Is there a way to disconnect these alarms to see if it is bad? I looked under the dash and its a mess, I'd like to remove it all together but not sure. Here's a pic of said car, and one of my pickup. I look forward to restoring this car, looks like it could take awhile!
ID:	110373   Click image for larger version
Dykzeulb is offline   Reply With Quote
Old 05-26-2013, 07:43 AM   #2
5.slow's Avatar
Region: Delaware
I'm not sure about the alarm and starting issue but I see the trick flow intake but are the heads aluminum trick flow heads? The issue you are talking about with the header melting the plug wire boot sounds like a common problem with gt40p heads, especially if it's the number 7 cylinder. If they are, 90 degree plug wire boots can sometimes prevent that problem depending on what headers you have.
5.slow is offline   Reply With Quote
Old 05-26-2013, 08:09 AM   #3
Dykzeulb's Avatar
The headers brand start with an e, it melted the front driver side wire
---------- Post added at 08:09 AM ---------- Previous post was at 08:08 AM ----------
And yes heads are truck flow
Old 05-26-2013, 08:21 AM   #4
Dykzeulb's Avatar
And yes heads are Trick Flow
Old 05-26-2013, 01:47 PM   #5
Dykzeulb's Avatar
If anyone is local, I'd really like for someone who knows these cars to come by and take a look at it and tell me what I have. So far everyone was impressed with the engine setup, but no one can really breakdown what I have in it, me getting into the stang world, I'm just learning
Old 05-26-2013, 01:52 PM   #6
MidnightBlueGT's Avatar
Ask whatever questions you need and us at ME will help out as much as possible. And welcome
Old 05-26-2013, 02:34 PM   #7
Billymich's Avatar
Yeah dude we can help you out. If you're near chicago I can drive my stang by and take a look.
Old 05-26-2013, 02:36 PM   #8
Dykzeulb's Avatar
Ha far from, I am in the Kansas City, Mo area.
I am going to remove the alarm tonight I hope all goes well- it looks like a mess
Old 05-26-2013, 02:38 PM   #9
Billymich's Avatar
Can you jump the solenoid ? Is this a manual?? Might be the neutral saftey switch
Old 05-26-2013, 03:08 PM   #10
Dykzeulb's Avatar
Yep I can start with jumping. It is a manual. According to the parts stores there is no nss on it
Old 05-26-2013, 03:15 PM   #11
Ubnbit's Avatar
That is a beautiful beautiful car! I would love to have its twin! So sweet!
Old 05-26-2013, 03:31 PM   #12
Billymich's Avatar
Lol you have a NSS
Old 05-26-2013, 03:31 PM   #13
Dykzeulb's Avatar
How do I test it
Old 05-26-2013, 03:32 PM   #14
Billymich's Avatar
I would start there
Old 05-26-2013, 03:39 PM   #15
93slowstang's Avatar
Originally Posted by Billymich View Post
Lol you have a NSS
Not in a manual, it's a clutch safety switch.
Old 05-26-2013, 03:46 PM   #16
Dykzeulb's Avatar
Is there a way to test it?
Old 05-26-2013, 03:48 PM   #17
Unplug it and it should allow you to crank the car even with the clutch depressed.
Old 05-26-2013, 04:18 PM   #18
Dykzeulb's Avatar
Where is it located?
Old 05-26-2013, 04:38 PM   #19
Billymich's Avatar
Under the dash, above the pedals. Do a search online if you dont have a haynes manual. A lot of forum discusions at other sites about this, a lot of people don't give info on it because they think idiots will bypass it.
Clutch Safety Switch? - Ford Mustang Forums
---------- Post added at 05:36 PM ---------- Previous post was at 05:36 PM ----------
neutral safety switch bypass
---------- Post added at 05:38 PM ---------- Previous post was at 05:36 PM ----------
Bypass neutral safety switch - Ford Mustang Forums : Corral.net Mustang Forum
Old 05-26-2013, 05:07 PM   #20
Dykzeulb's Avatar
Old 05-26-2013, 05:17 PM   #21
Billymich's Avatar
Dude look online theres no good way to discribe it, its under the dash above the clutch pedal. You cant just unplug it, you have to jump it with a fuse
---------- Post added at 06:17 PM ---------- Previous post was at 06:16 PM ----------
MOTORCRAFT SW2063 Mustang Clutch Neutral Safety Switch 86/93 | CJ Pony Parts picture of what it looks like
Old 05-26-2013, 06:13 PM   #22
Dykzeulb's Avatar
I can see the switch - tore out the aftermarket alarm too to see if that was the issue..it wasnt, but had to go anyways, re soldered all connections.. replaced ignition switch...this has to be the issue I hope! How do I go about jumping it with a fuse, I see it has plugs, but not the slightest idea on how to jump it.
Old 05-26-2013, 06:52 PM   #23
Dykzeulb's Avatar
After a little searching, I placed a 20 amp fuse in the plug with the 3 wires, two red / 1 blue iirc, still didnt fire. I turn the key and about the time it should turn over the air shuts off for a split second and the low oil light comes on ....wtf
Old 05-26-2013, 07:39 PM   #24
Bane-'s Avatar
the NSS is the only plug connected to the pedal box by the clutch/brake assembly. unplug it an see if the car will start/turn over.
Old 05-26-2013, 08:25 PM   #25
Billymich's Avatar
I stand corrected yeah its a Clutch safety switch, but you know what I mean, there are two plugs on the connector, one needs to be jumped with the blade fuse, one doesn't if that doesn't do it for you, the CSS is not your issue.
Old 05-26-2013, 08:30 PM   #26
Dykzeulb's Avatar
I am at a lost- I am thinking the prev owner wired the solanoid up. I bought a new bw select solanoid but wired it how he had it. There was one smaller gauge wire on the post next to the battery, really small one in the center, and a huge cluster on the other side, I am assuming for the msd ignition ect.
---------- Post added at 09:30 PM ---------- Previous post was at 09:29 PM ----------
I thought the battery cable went to the post closest to the battery, no? That's how my tractor is wired, I know this isn't a John Deere, but just didn't seem right
Old 05-26-2013, 08:36 PM   #27
Billymich's Avatar
Hey I had a similar thread going a few months ago Ill try to find it
Old 05-26-2013, 08:48 PM   #28
Billymich's Avatar
Starter/Clutch/need help fast
All I could find so far, Ill keep looking for the one
Old 05-26-2013, 08:58 PM   #29
Billymich's Avatar
Can you just take a picture so I can see what we're working with here. Easiest way to tell
Old 05-26-2013, 11:30 PM   #30
Dykzeulb's Avatar
Here's how the solanoid is now, seems to be right
Old 05-26-2013, 11:31 PM   #31
Dykzeulb's Avatar
Also, billy I jumped the clutch safety switch and it didn't still didn't work.
Old 05-27-2013, 02:44 AM   #32
Billymich's Avatar
yeah, wiring looks good, if the CPS jumping didnt work then I don't know what your issue is. I'll look into a bit tom
Old 05-27-2013, 07:29 AM   #33
Dykzeulb's Avatar
Would it make a difference if the old solanoid was 3 prong and this one is 4 prong? It has two small posts, and two large posts
Old 05-27-2013, 07:55 AM   #34
Dykzeulb's Avatar
Well, started early this morning and found some cool stuff from the prev owner (thankful) although it didn't fix my problem it gave me motivation to keep working on it- these are parts on the dates installed, prior to the car being parked in 2005.
Also the last photo is of mapquest directions to KCIR- this hits home for a lot of people as the city has since shut the track down, anyone who has ever raced drag locally has a sour taste about the city and what they did
Ok- back to wiring.
Fuseable link?! What the hell is it? This is the first time I have heard about it, and see it no where mentioned in my 92 explorer manual.
ID:	110619   Click image for larger version
ID:	110621   Click image for larger version
Old 05-27-2013, 08:59 AM   #35
92coupe's Avatar
Did you require the ignition without the alarm on the car? Would the alarm go off whenever the car wouldn't start?
92coupe is offline   Reply With Quote
03:36 AM
