is this a T5 tranny? - Mustang Evolution
Old 05-25-2013, 11:04 PM   #1
busaboy's Avatar
as with my other posts nothing seems to be what it was supposed to be
I have googled it but my untrained eye cant tell especially while I am this aggrivated so if anyone can tell and just let me know for certain, I can take more pics if needed, thanks
busaboy is offline   Reply With Quote
Old 05-25-2013, 11:06 PM   #2
deadsp0t's Avatar
Yup
That's unimpressive
Old 05-25-2013, 11:12 PM   #3
busaboy's Avatar
anyway to tell if its any good while its unhooked?
Old 05-25-2013, 11:22 PM   #4
deadsp0t's Avatar
That I'm not sure, all the signs I know are mostly when driving or shifting. There may be some here who can tell you a few things to look for.
Obvious things are visible leaks, or scoring on the input shaft.
I know someone locally who runs 30W motor oil instead of trans fluid and has had great success with his T5 lasting over 10 years behind 350hp and nitrous. He, and others say the only downside is shifting is a little notchy until the oil warms up, but once warm it's super smooth and lasts.
That's unimpressive
Old 05-25-2013, 11:44 PM   #5
busaboy's Avatar
hmmm interesting, any idea what other motors it'll bolt to?
Old 05-26-2013, 12:17 AM   #6
deadsp0t's Avatar
It will bolt to a lot of engines, both Chevy and Ford.. With that bell housing it will bolt to a 302 or 351W..
There are diff bells or adapters that allow it to be used with diff engines.
I will add, my buddy that's had such good fortune with his T5 has been very lucky..
The T5 is a decent box but generally doesn't live too long in high HP applications, unless built..
G-Force out of PA I believe builds some seriously stout T5 boxes
That's unimpressive
Old 05-26-2013, 12:18 AM   #7
Billymich's Avatar
Looks like mine at least before I cleaned it. Car it came off was probably leaking coolant and oil. I use ATF for my t-5
Old 05-26-2013, 08:53 AM   #8
bnoist114's Avatar
Thats def a T5. It looks to have came out of an 86 or older stang. I have an 85 an the bellhousings are a lil different on these than newer 1s. I got a used 1 out of a 95 gt an my starter wuldnt fit inside housing so i had to get starter for a 95 also. Other than obvious grinding sounds frm turnin input by hand an going thru gears, theres not too many ways to spot a prob unless u take apart to see gears or have it in car
bnoist114 is offline   Reply With Quote
Old 05-26-2013, 04:02 PM   #9
deadsp0t's Avatar
Bells are universal until 94-95, the 94-95 T5's have a slightly longer input shaft, hence the different bell.
That's unimpressive
Old 05-26-2013, 04:33 PM   #10
Billymich's Avatar
Yeah, I was gonna say looks exactly like my 88 bellhousing, check the fluid color that is you best bet to figure out if its WC or non world class without checking snychros
Old 05-26-2013, 07:13 PM   #11
busaboy's Avatar
What am I looking for as far as fluid color? World class vs ????
Old 05-26-2013, 07:46 PM   #12
Bane-'s Avatar
not all t5's were made equal...
COOL CATS Celebrating the 1983-88 Mercury Cougar Modifying : Ford Borg-Warner T-5 Manual Transmission Data you can look up the tag on the trans (if its still on it) and see which version you have.
Old 05-26-2013, 08:26 PM   #13
Billymich's Avatar
World class vs non world class, world class should use pink ATF non world class uses ?gear oil?
My 88 has a WC t 5
they switched in 85 (cars built in 84)
Old 05-27-2013, 09:15 AM   #14
busaboy's Avatar
Mine was def pink...it went all over my floor... lol
« Ride hight | Clutch »
06:16 PM
