Belt Measuring ? - Mustang Evolution
Old 05-26-2013, 11:52 AM   #1
WhiteCobra94's Avatar
Belt Measuring ?
Ok I just measured for new belts without any tension on the tensioner and it came to
Belt without smog and AC is 82in
Belt without smog is 90in
Belt without AC is 92 3/4 in
Now how much do i minus off for the tensioner ?
Old 05-28-2013, 07:02 PM   #2
Thanks!!!!
Old 07-11-2013, 07:50 PM   #3
Anyone? ...... Anyone?...... Someone?
Old 07-11-2013, 08:26 PM   #4
Sgt_Syke's Avatar
U don't, if anything you add an inch. If u measured without a tensioner, then the belt needs to be longer.
Sgt_Syke is offline   Reply With Quote
Old 07-11-2013, 08:30 PM   #5
No I added it with the tensioner but with no tension on the tensioner , if I go longer the tensioner won't do anything
Old 07-12-2013, 09:32 PM   #6
Route a piece of twine around your pullies in the exact same pattern as whatever your routing is (not sure if you've deleted anything). Then have a buddy grab the ratchet and go to full tension on the tensioner. Pull the twine tight, mark it and measure it.
Old 07-14-2013, 11:52 AM   #7
Sgt_Syke's Avatar
+1scotty, or look up online, I've found it on there before For all diff combos of accessories.
Old 07-14-2013, 12:22 PM   #8
Yea a tech from summit racing told me to engage the tensioner 1/2 way when measuring
Old 07-14-2013, 01:22 PM   #9
5.slow's Avatar
Region: Delaware
See if this diagram helps
5.slow is offline   Reply With Quote
Old 07-17-2013, 10:38 AM   #10
Sgt_Syke's Avatar
I used this same diagram, I have factory minus sp, worked perfect.
Old 07-17-2013, 11:43 AM   #11
But my measurements are different from that diagram
Old 07-17-2013, 11:58 AM   #12
deadsp0t's Avatar
There is a diagram floating around specific to SN95 5.0's the A/C and PS are in different locations.. I believe I've posted on here before, if not use google images or bing images, it'll pop up.
That's unimpressive
Old 07-17-2013, 12:01 PM   #13
5.slow's Avatar
Region: Delaware
I didn't realize it was a 94. Try this.
Old 07-17-2013, 12:09 PM   #14
351stroker's Avatar
Only way to do it.
---------- Post added at 12:09 PM ---------- Previous post was at 12:04 PM ----------
I got two different size belts on both my cars.
Both 88's. not too sure what the difference is cause I haven't looked to closely. I used a piece of string wrapped it around and measures with my tensioner in the middle of the safe marking. A buddy of mine actually somehow turned the tensioner around to lift up for tension. Not to sure how it worked.
351stroker is offline   Reply With Quote
Old 07-17-2013, 12:10 PM   #15
deadsp0t's Avatar
The diagram I was referring to.
With so many having already done these set ups there's really no need to beat your knuckles up 'old schooling it' enjoy
That's unimpressive
Old 07-17-2013, 05:10 PM   #16
Not really sure what all these diagrams are going to accomplish or the conjecture... I already mentioned the best way for him to figure out EXACTLY what length he needs in about 5 minutes with no guesswork... This thing called Empiricism...
Old 07-17-2013, 05:21 PM   #17
5.slow's Avatar
Region: Delaware
Apparently this forum should be called "ask Scotty" because apparently his opinion and know it all wisdom is all that matters. Everyone else's opinion and advice is merely discussion fodder for him to discredit. I think I'm finally done with this forum. Later!!
Old 07-17-2013, 06:38 PM   #18
2300turboford's Avatar
Don't let the door hit ya where the good lord split ya and yeah his post was the best way to do it don't get buthurt bc someone is smart
Old 07-17-2013, 06:56 PM   #19
Four Eyes's Avatar
That was a little un needed..
The original poster obviously doesn't know what to do with these diagrams, so Scotty just gave him the easiest, most fool proof way to figure out. Simple..
1986 GT with the typical poor boy mods. 3.73s, Hurst short throw, King Cobra Clutch with aluminum quadrant, lowered two inches on Eibach springs, Hopefully adding some heads and a decent intake soon!
Four Eyes is offline   Reply With Quote
Old 07-17-2013, 08:20 PM   #20
Drama bombs! Good thing the diagrams he posted accounted for pulley sizes other than stock like underdrives... oh wait they don't...
Old 07-17-2013, 08:46 PM   #21
Sgt_Syke's Avatar
Some ppls kids
02:03 AM
