Injectors not firing - Mustang Evolution
Old 05-27-2013, 06:33 AM   #1
93turbocobra's Avatar
I am working on my brothers 87 lx 5.0 and his injectors are not firing. Seems as if he has no power going to them at all. I used a noir tester and it did not light up so we changed the relays and the pickup in the distributor. And still the same thing, it will start and run for a second if you use starting fluid or gas but it does when it is gone anyone out there have any suggestions
93turbocobra is offline   Reply With Quote
Old 05-27-2013, 10:02 AM   #2
DustyStang306's Avatar
Hey i had the same problem it was my PCM it was fried if you can get your hands on one to test an see then I'd do that
DustyStang306 is offline   Reply With Quote
Old 05-27-2013, 01:15 PM   #3
Ok thanks I will try that
Old 05-27-2013, 02:55 PM   #4
Billymich's Avatar
If i ever do my MAF you can have my old one, or if you want I can send you my old one and you can paypal me so I can buy a CAI or even some PVC pipe to fit my MAF
1988 mustang 302 5-speed
Old 05-27-2013, 04:41 PM   #5
How much would you want for it
Old 05-27-2013, 04:48 PM   #6
You should be abel to get a used one for 125 to 225$ an if your using a 5 speed you can use ether one of the two the a9l was for standard and the a9p was the auto but you the a9p will work fine with a standard to
Old 05-27-2013, 04:57 PM   #7
Ok but it would have to be out of a speed density car not a maf car right
---------- Post added at 05:57 PM ---------- Previous post was at 05:54 PM ----------
It would have to be out of a speed density car correct not a maf car
Old 05-27-2013, 05:08 PM   #8
Haha sorry I just seen the motor in your profile pic an your name thought you had a 93 but I'm not the guy to talk to about speed density isn't speed density hard to work with in its tune ability?
Old 05-27-2013, 05:42 PM   #9
I do have a 93 cobra but the car I am working on is my brothers and what's wrong with my engine
Old 05-27-2013, 05:51 PM   #10
I do have a 93 cobra it is my brothers car I am working on and what's wrong with my engine
Old 05-27-2013, 07:42 PM   #11
Nothing wrong I just thought it was a mass air car because of the pic didn't see it was a 87 an your brothers haha kinda missed that lol but your motor look nice man what's the specs? An do you got a turbo already?
Old 05-27-2013, 07:46 PM   #12
Billymich's Avatar
Well I'd be willing to sell it for 150 probably, let me look into It a tiny bit, Im in chicago where are you ?
Old 05-27-2013, 08:02 PM   #13
Billymich's Avatar
For Sale 1988 DA1 speed density cpu - Ford Mustang Forums : Corral.net Mustang Forum
dude said $40 shipped
Old 05-27-2013, 09:05 PM   #14
It is a 306 and I am still looking for a turbo and thanks for the info
Old 05-28-2013, 10:04 AM   #15
Nice my is a 306 to but you still got stock heads? And I was looking at the hellion turbo kit and got lots of guys that Say they love them an I haven't hear anything bad about them yet
Old 05-28-2013, 01:53 PM   #16
I have gt 40 heads that have a 3 angle valve job the bowls have been blended and they have been ported and swirled on the intake side and polished on the exhaust side
Old 05-28-2013, 04:22 PM   #17
Ye man that should work good for a turbo set up is it a stock block?
Old 05-28-2013, 04:27 PM   #18
Nope forged crank, forged I beam rods , forged pistons and trick flow cam
Old 05-28-2013, 08:16 PM   #19
Lol nice man but I meant just the block it self haha the stock block is only good for about 500rwhp with a safe tune
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
An probably won't last to long at 500rwhp but what are you going for in HP#?
Old 05-28-2013, 08:18 PM   #20
The block is stock and I have done se research and I also have a friend that has about 700 with 17 psi on it and it has been running for about 3 years
Old 05-28-2013, 08:25 PM   #21
The number I am looking for is any where from 500 to 550 not a lot because I also drive the car daily
Old 05-28-2013, 08:30 PM   #22
Well it's your build so if your will to go that high on a stock block then do it up lol I wouldn't go passed 450rwhp my self on my stock block
---------- Post added at 09:30 PM ---------- Previous post was at 09:27 PM ----------
Well at that high you may keep it for a bit keeping the rpms low still wouldn't go that high
Old 05-28-2013, 08:35 PM   #23
I don't know what it will be at so I will see I have been working on it for about 2 years now. I only gonna run about 12 psi so it will probably be about 450 or so but I don't know yet
Old 05-28-2013, 08:42 PM   #24
Haha ye man I would go with a s trim they have made 450rwhp + on gt40 set up many of times and it's good for DD an you can pick up a good uses s trim for your set up an be there quicker then the turbo although the turbo would be bad a*s hahah
Old 05-28-2013, 09:01 PM   #25
Where would be a good place to look for an s trim
Old 05-28-2013, 09:08 PM   #26
Sounds good where would be a good place to look for one
Old 05-28-2013, 09:20 PM   #27
I'm in Canada so I use kijiji but I think in the usa you guys use craigslist don't ye... An you can get a new v3 vortech from AM for 2254.99 but it's a 6 psi unit you could run 8 psi on here's a link on it
http://www.americanmuscle.com/mustan...er-8693v8.html
Old 05-29-2013, 07:36 AM   #28
Thanks
Old 05-29-2013, 10:25 AM   #29
So what so you think about meth injection
Old 06-01-2013, 09:16 AM   #30
Well we have changed the computer and the ignition control module and the pick up in the distributor and the car still will not start. I am getting power to the red wire when the key is off and when we try to start it I have power to the other wire so what could it be. Any help would be appreciated!
Old 06-01-2013, 02:20 PM   #31
Billymich's Avatar
Clutch Position Sensor maybe?
Old 06-01-2013, 03:14 PM   #32
It turns over it seems like it is not getting fuel when you use starting fluid it will start but them die when that is all gone
12:38 AM
