Idle problem - Mustang Evolution
Old 05-27-2013, 12:01 PM   #1
88ShiftyFifty's Avatar
Idle problem
I changed the egr valve. Egr valve sensor and the air idle control valve to pass smog and it passed with ease. Since then, after the car running for a little while the rpms shoot up to 2000-2500 at idle. Also when I let off the gas the rpms want to stay around that high so the car won't coast. I have off road h pipe with 40 series flows so at stop lights I feel like people look at me thinking I'm a ****** for giving it gas while I'm sitting there. Lol.
Any thoughts?
88ShiftyFifty is offline   Reply With Quote
Old 05-27-2013, 02:53 PM   #2
Billymich's Avatar
Sounds like a vacuum leak. Grab a length of hose and move it around the engine bay with one end in your ear, under the upper intake manifold especially, but the egr stuff too. You'll hear it when you get close to a leak.
Try cleaning your MAF too did you reset base idle?
Old 05-27-2013, 04:21 PM   #3
No I didn't. How do I reset base idle?
Old 05-27-2013, 07:43 PM   #4
Billymich's Avatar
Summarized/Corrected Base Idle Reset Procedure
Old 05-27-2013, 09:40 PM   #5
87blackonblack's Avatar
I had the same problems went through the vacuum hoses nothing cleaned the maf iac throttle body and followed similar steps to the link you posted and Waaa laaaa problem solved!
87blackonblack is offline   Reply With Quote
Old 05-27-2013, 11:45 PM   #6
Billymich's Avatar
Yup pretty common issue.
Old 05-29-2013, 08:00 AM   #7
moyhuerta91's Avatar
ive had the same issue too but i had to change my whole MAF sensor once i changed it it ran like normal agien nd idle was bakk were it as supposed to
moyhuerta91 is offline   Reply With Quote
« foglights | Hp »
11:20 AM
