Sve v sr proformance cold air intake for 94 gt - Mustang Evolution
Old 05-28-2013, 06:43 AM   #1
94gtconvert's Avatar
Which one is better. There the same exact price, but I herd the sr performance need a slight mod to a plastic thread for a sensor to fit perfect. There are no reviews on the sve one. Which one is better made, better quality filter element?
94gtconvert is offline   Reply With Quote
Old 05-29-2013, 06:54 AM   #2
Where can I get a cai that is not a fender one, like kne that stays in the engine compartment as opposed to using the snorkel hole
Old 05-29-2013, 07:13 AM   #3
McNassty's Avatar
I'm not sure which is better but you don't want an underhood one, its put into the fender so that it doesn't suck in hot underhood air instead it pulls in cooler fresh air
McNassty is offline   Reply With Quote
Old 05-29-2013, 08:22 AM   #4
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
+1. Fender well mounted CAI is the best choice.
---------- Post added at 02:22 PM ---------- Previous post was at 02:17 PM ----------
There shouldn't be a big difference between the two. I would lean towards the one with the largest tubing, and/or a larger cone filter.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 05-29-2013, 04:51 PM   #5
Thanks for the input
Old 05-29-2013, 06:03 PM   #6
I had a BBK and it was OK. The MAC is ok or just make your own. The ones that put the inlet in the fender is what you want, if it doesn't its not a CAI its a HAI (hot air intake). The BEST ones are the ones that put the MAF in the fendewell. You have to lengthen some wires and the filer goes right on the MAF. Pretty sure you have to build one yourself for that setup but it isn't hard.
Old 05-29-2013, 08:56 PM   #7
But my main question is why brand do you guys trust more, sve or sr performance ok they are the same price. Sve or sr??
Old 05-29-2013, 09:47 PM   #8
McNassty's Avatar
Seriously their pretty much all the same without a tune and even with a tune they are within +-1hp of each other so just pick which one looks best and makes you happy
Old 07-04-2013, 11:28 PM   #9
Should I use rtv between the maf an the flange on the new cai. The instructions say no gasket needed but I think it would be better safe than sorry right??
Old 07-05-2013, 02:42 PM   #10
Ewokjax95's Avatar
On my old CAI, it had a seal between them but it was uneven on two sides so I took it off. Never had a problem.
Ewokjax95 is offline   Reply With Quote
Old 07-05-2013, 03:01 PM   #11
Site Sponsor
Sponsor
AMWill's Avatar
94gtconvert,
The SR Performance CAI is a great kit. For the price and performance, it's hard to beat it. I I think you'll be more than happy with the SR intake, if you decide to go that route!
There's truly no need to add RTV sealant to the flange. There's more than enough seal for the CAI work flow air properly through the MAF. Plus, you don't want to risk any chemicals getting onto the MAF sensor.
Hope this helps!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 07-05-2013, 08:26 PM   #12
Billymich's Avatar
You want your filter as far from your MAF as possible... Scotty you are really dumb
Old 07-05-2013, 08:36 PM   #13
Please elaborate on your position and why so many ppl relocate their MAF into the fenderwell.
Old 07-06-2013, 12:30 AM   #14
I would pick whatever cai u think looks the best imo. There isnt really large gains to be had unless your choking down a high hp motor. Also dont worry about a tune with your cai. No fox cai will need a tune.
88stanger is offline   Reply With Quote
Old 07-06-2013, 10:25 PM   #15
Thanks guys, I know sr proformance is a cheaper intake so if the flange comes warped witch is not unheard of I will make a silicone gasket, only because the sve intake from latemodlerestoration uses a gasket. Hey it wa the 4th of July sale the sr intake was 65 bucks while the sve is 85 so you can't really go wrong.
Old 07-07-2013, 08:35 AM   #16
Or you could do a semi-custom one like mine.
C&L pipe to a custom fabbed sheetmetal air shield around the filter.
Although according to some ppl this is bad because the filter is right by the MAF. Yeah my car really runs terrible...
Old 07-07-2013, 09:00 AM   #17
slow281
sixpac's Avatar
Region: Nebraska
Lol that's we're airaid puts there's..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-07-2013, 09:56 AM   #18
A cold air intake is a cold air intake in reality they probably take away a horse or two. I just want it so in the feature I can up grade my maf size and throttle body to make my 5.0 ready for a trick flow intake and some brodix heads and a stage 2 cam. Then the cai will be a horse power adder in that case. Also I like the custom intake you guys have, the filter is much larger than mine lol; you get what you pay for. In my opinion airaid is probably the best Brand and steeda and bbk a close second k&n is overpriced for what it is.
Old 07-07-2013, 10:06 AM   #19
slow281
sixpac's Avatar
Region: Nebraska
Yepp airaid has a nice finish they make it look good cost me 230$ but worth it..
2001 GT - True Blue
Old 07-07-2013, 11:57 AM   #20
Billymich's Avatar
Airfilters especially cheap ones create turbulence, and the farther the sensor is from the filter the more accurate (unless MAF was designed as a filter on MAF)
05:53 PM
