Pilot bearing question - Mustang Evolution
Old 05-28-2013, 10:47 PM   #1
Ewokjax95's Avatar
Getting ready to install Spec stage 3 clutch and FRPP pilot and throwout bearings, Prothane trans mount, and FRPP rear main seal. What type of grease should I use to pack the pilot bearing and remove it hydraulically?
Ewokjax95 is offline   Reply With Quote
Old 05-28-2013, 10:48 PM   #2
Venomouz831's Avatar
The kits usually come with them. Ask who ever you're getting it from
)02 Gt, Founder of WE2G
Old 05-28-2013, 11:11 PM   #3
Ewokjax95's Avatar
What I meant was the grease used to remove the old pilot bearing. I've never done it before but I was told to use something like silicone or wheel bearing grease. You're supposed to fill the middle of the bearing to get it airtight and insert something that fits in the hole and hammer it in till it pushes the old bearing out hydraulically.
Old 05-29-2013, 09:07 AM   #4
havhammer's Avatar
Idk about that but I've always used a pilot bearing puller tool. Not too expensive and if you do it the other way you have to worry about getting all the grease out so as not to contaminate the clutch disc. And don't pack the new bearing cuz they already come packed and again yoy don't wanna get grease on your clutch parts. You can probably rent the tool from somewhere like autozone. And don't get me wrong - I'm not endorsing autozone! Lol
havhammer is offline   Reply With Quote
Old 05-29-2013, 11:33 AM   #5
I've used slam hammers to get mine out but you can pack it with just about any grease and do it hydraulically too. Hell even bar soap packed in real tight works well.
Old 05-29-2013, 01:26 PM   #6
Ewokjax95's Avatar
Here's a couple pictures of the pressure plate and disc. There's no material on the pressure plate side of the disc at all.
ID:	110998   Click image for larger version
Old 05-29-2013, 02:11 PM   #7
I hope you are getting a new flywheel or at least getting yours checked and resurfaced lol. That was definitely time for a change...
Old 05-29-2013, 02:56 PM   #8
Ewokjax95's Avatar
Flywheel is getting resurfaced and balanced at the least. I'll have them check it and let me know if its still roadworthy as well.
Old 05-30-2013, 04:48 PM   #9
Billymich's Avatar
Yeah dude that ended badly, like I said at least you didnt lose a foot, I would recommend just chiseling it out, that's how I had my best luck.
11:28 PM
