attention all gear heads...... - Mustang Evolution
Old 05-29-2013, 07:49 PM   #1
Krazy Horse's Avatar
I'm in process of building a 88 hatch gt, have built 331 with stock injectors and Cobra intake, t/f cam and x code heads. Have Cai and ordering new Maf but want to know what injectors I should use
Krazy Horse is offline   Reply With Quote
Old 05-29-2013, 08:05 PM   #2
stevec666's Avatar
If staying naturally aspirated then 36lb/hr will work fine.
stevec666 is offline   Reply With Quote
Old 05-29-2013, 09:44 PM   #3
That's not too much fuel ?? Was thinking about going with 30# due too I'm ordering a bbk maf, I have swapped the entire body and engine harnesses and using a a9p pcm
Old 05-29-2013, 09:49 PM   #4
McNassty's Avatar
At least 36lbs. You will really find out if you need larger injectors when you dyno tune it
McNassty is offline   Reply With Quote
Old 05-30-2013, 06:28 AM   #5
OK thanks for the advice guys
Old 06-21-2013, 06:44 AM   #6
What about a bone stock motor with bbk SSI intake, Cai, headers, and maf. All bbk but running stock injectorsand seems really lean, like burns your eyes lean. It's a 92 gt with stock cam but motor is .030 over. It has an idle demon and timing sounds off due to valve rattling under load but am running 12 degrees btdc and premium fuel. What size injectors should be in this one ??
Old 06-21-2013, 09:41 AM   #7
Burning you eyes doesn't sound lean to me, sounds to rich.....
eightlives is offline   Reply With Quote
Old 06-21-2013, 09:52 AM   #8
wc3john's Avatar
Burning of the eyes is burning too much gas.
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 06-21-2013, 10:01 AM   #9
Again, doesn't sound like it is burning too much, sound like not burning enough, therefore there is more vapors that aren't being burned off
Old 06-21-2013, 10:30 AM   #10
wc3john's Avatar
Sorry that's what I meant... Either too much fuel is being dumped or not enough spark in the cylinder to burn all the gas supplied
Old 06-21-2013, 10:36 AM   #11
DustyStang306's Avatar
+1
DustyStang306 is offline   Reply With Quote
Old 06-21-2013, 06:28 PM   #12
Ah ok, that makes sense, now we are on the same page. That being said I had a similar problem with the 347 stroker in my Lincoln, and I believed I fixxed it by installing a msd box.
Old 06-26-2013, 05:14 PM   #13
I just finished installing 30# injectors and my crazy idle calmed down, car runs cooler and the fumes are gone ! My problem was fixed but I had 2 injectors that fell apart as I was taking them out so may have had another issue there too. But its all good
Old 06-26-2013, 05:22 PM   #14
wc3john's Avatar
Sounds like the injectors then...
08:58 PM
