Rear upper bushing sleeve - Mustang Evolution
Old 05-31-2013, 05:07 PM   #1
94_2valves's Avatar
I bought some sr rear control arms and when taking the old bushings out ok the housing, I damaged the metal sleeves for the upper part.
Does anyone know what these are called where to get any by themselves.
Thanks
94_2valves is offline   Reply With Quote
Old 05-31-2013, 09:21 PM   #2
fastmustangs1's Avatar
I take it you have a pre-05 mustang. If so you will need a UCA bushings press tool.
Here is a link Maxi Mo for the bushings,
Mustang Rear Upper Control Arm Bushings, Axle/Differential Side, pair [E4SZ-5A] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Rear Upper Control Arm Bushing Tool [MMT-1] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
---------- Post added at 10:21 PM ---------- Previous post was at 10:16 PM ----------
You could try spraying the sleeve with WD 40 before using the press tool.
fastmustangs1 is offline   Reply With Quote
Old 06-01-2013, 10:01 AM   #3
94_2valves's Avatar
Ya it's a 94. Have you ever Installed polys on the these before? Sucks cause I just need the sleeves cause others are damaged, or I just suck it up and buy the reg style bushings with o e already attached.
Ya that's nice to know. Probably could dupe that with some parts around the garage.
Old 06-01-2013, 11:33 AM   #4
I do not recommend going with any polyurethane bushings in the upper control arms. You will increase suspension bind not good and could possibly damage the torque boxes. I would just replace them with OEM rubber bushings.
I would get the Maxim Mo bushing press tool because it will install the bushing
in the axle to the correct depth.
Old 06-01-2013, 01:47 PM   #5
94_2valves's Avatar
I guess when ppl buy a set of arms, they disregard the poly bushings for the torque box and just use a rubber bushing.
Old 06-01-2013, 03:28 PM   #6
No u can pressin new rubber bushings into the arms.
08:40 AM
