Starting problem - Mustang Evolution
Old 05-31-2013, 06:19 PM   #1
Sgt_Syke's Avatar
Starting problem
Intermittent start, when it doesn't start I don't hear fuel pump. When it starts I hear it. I've replaced ignition switch. Grounds to solenoid are good. Battery is good and clean connections. What could it be?
Sgt_Syke is offline   Reply With Quote
Old 05-31-2013, 06:50 PM   #2
94_2valves's Avatar
Check the neutral safety/ clutch switch
94_2valves is offline   Reply With Quote
Old 06-01-2013, 02:48 AM   #3
93slowstang's Avatar
If its turning over and won't start you may want to check the fuel pump relay.
Old 06-01-2013, 10:19 PM   #4
Sgt_Syke's Avatar
I double checked and fuel pump works everytime, I just couldn't hear it on the day I posted my question b/c of other noise. So, what else can I check?
---------- Post added at 09:18 PM ---------- Previous post was at 09:17 PM ----------
Oh, when it doesn't start, I get lights and fuel pump, but no crank.
---------- Post added at 09:19 PM ---------- Previous post was at 09:18 PM ----------
I'll look into the n/s switch. I have a multimeter, but working this weekend.
Old 06-02-2013, 12:06 AM   #5
vonHildegard's Avatar
This is random, but I had a starting issue a while back that was kind of hard to trace and had some similar symptoms. Lights, fuel pump, turnover, no crank. Checked coil, plugs, injectors, fuel pump, ignition- turns out my MAF ECU was shorted out by an improper ground in my CAI. Good luck!
vonHildegard is offline   Reply With Quote
Old 06-02-2013, 07:26 AM   #6
Sgt_Syke's Avatar
Thanks, I'm all stock right now, so no cai, but could it be a ground elsewhere?
Old 06-02-2013, 11:03 AM   #7
It's possible! When we were checking for codes we were unable to get a response from the computer so that's how we figured it out. You checked the distributor and coil? Plugs and wires? Have you done any work recently to it? Also, pull the fuse for the cigarette lighter- sometimes that can be an electrical culprit.
03:12 PM
