Blinkers stopped working?! - Mustang Evolution
Old 06-03-2013, 06:17 PM   #1
Adogg's Avatar
So my blinkers stopped working today so when I turn them on left or right the little green arrow doesn't come up at all. What do you guys think is the problem?
Don't hate....... appreciate
Old 06-03-2013, 09:04 PM   #2
mustangmania91's Avatar
I had the same issues. more than likely its your relay. However, if the relay has been changed it can also be your turn signal/multi switch. I actually changed both and mine works fine now
mustangmania91 is offline   Reply With Quote
Old 06-04-2013, 09:47 AM   #3
Adogg's Avatar
Thanks man. Where are these two switches located and can I buy them at a regular parts store? How much where they?
Old 06-04-2013, 06:28 PM   #4
The relay u can buy at most auto stores like autozone,advanced auto or o'reilleys. The multi switch u cant. Buy it feom cjponyparts.com or latemodelrestoration.com. the multi switch is fsirly expensive, however I purchased mine from ebay and it was new for roughly $40. Just be sure it has the wiper washer on it as well
Old 06-05-2013, 07:37 AM   #5
Also, the multi switch sells between $40-$150. The higher is OEM and/or original replacement. Check ebay first, just be sure u order it new and again with the window washer included
Old 06-05-2013, 12:43 PM   #6
alexak187's Avatar
Region: Arkansas
I just fixed mine yesterday, after checkin every wire and nearly taking the dash out completely, it turned out to be a wire came loose behind the multi switch. I might check that.
alexak187 is offline   Reply With Quote
Old 06-05-2013, 01:48 PM   #7
Adogg's Avatar
Unplugged the relay and the fuse put it back together and so far I have had now problems must have been a bad connection some where I feel like the problem may resurface
04:07 PM
